medusa - seemed like a good idea at the time.
by tldr on Sun Mar 17, 2013 1:52 am
went something like this. get a set of 6" premium male to male jumpers. peel off a group of 26 wires. install idc connector near one end. trim cable. install on pi in cool fluorescent green pi box.
notes to self:
    - do not plug this in. something will short out.
    - next time use female jumpers. most adafruit breakouts come with male headers.
    - idiot.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
Re: medusa - seemed like a good idea at the time.
by adafruit_support_mike on Wed Mar 20, 2013 3:23 pm
I'd suggest cutting off some of the terminators to see if two grow back for every one you cut, but that probably wouldn't be very responsible of me. ;-)
On the bright side, you can probably split that one into bands 3-5 conductors wide and end up with something handy.
by tldr on Fri Mar 29, 2013 1:54 pm
so, this may be the better approach. 6" female/female jumpers. first of all it's none destructive, since instead of crimping on an idc connector i just stuck them right onto the header on the pi then wrapped them in painter's tape rendering a slightly wobbly, but serviceable connector. the appropriate pins at the other end were attached to the male header on a 16 servo breakout. i'll also be using the serial pins to get a console on my laptop, 'til i get the network configured, and maybe hook up the spi pins to a nokia 5110 display.
the connectors on the jumpers are too tall to put the lid on the pibox, but i figure next time i'm close to a laser cutter i'll just make a lid with a hole in it.
tldr
by adafruit_support_mike on Fri Mar 29, 2013 8:18 pm
That's a nice trick.. I'll have to steal that. ;-)
by tldr on Fri Mar 29, 2013 9:38 pm
cool thing about thei2c servo breakout and the spi nokia breakout that i'm using is that they both have two sets of headers so i can easily extend the bus and power to another board like maybe a ds1307 breakout on the i2c bus. unfortunately, the ds1307 and many other breakouts have only one set of bus and power pins, so devices cannot be easily daisy chained.
tldr
