Connecting Raspberry Pi with Wifi Module
Re: Connecting Raspberry Pi with Wifi Module
by adafruit_support_rick on Thu Mar 07, 2013 7:27 pm
Might be worth a try. If nothing else, you'll have a spare hub! :D
by adafruit_support_rick on Thu Mar 07, 2013 7:29 pm
Maybe try a different cable, too...
by pandring on Tue Mar 19, 2013 9:21 pm
Soo...
I'm back yet again with a DIFFERENT problem now. Tonight, I tried to ssh into my pi over wifi (as I've been doing every day for the past two weeks), and I wasn't able to connect to it. I logged in to my router's admin panel, however, and it says that the raspberry pi is connected to the wifi, and I can use the router's "test connection using ping" feature to ping the pi. However, I can't ping or ssh into the pi from any other computer on the network.
To make it weirder, if I plug in a ethernet cable, (I'm able to ssh, even using the pi's wireless IP, if there's a cable), and I check ifconfig everything looks normal; wlan0 is up and running, and transferring a small amount of data (about 1.7 KiB), while the ethernet is transferring the rest. When I unplug the ethernet cable, however, my ssh connection is dropped and I can no longer ssh or ping the pi.
Do you know what might be going on this time?
pandring
by adafruit_support_rick on Wed Mar 20, 2013 10:09 am
Could be a quality of service thing - all the hardware thinks it's connected, but the packets really aren't getting through reliably. For comparison, I can VNC into my Pi on a wired connection, but not over WiFi. Don't know for sure, but I assume that it's because my wifi connection quality just isn't up to snuff.
