G is for GROUND! The latest Circuit Playground is here!
Low profile microSD adapter
by jeff520 on Mon Apr 08, 2013 11:42 pm
This item will not plug in to a Raspberry Pi mounted in a Ninja Pibow box. It is too thick, and the box only allows a regular SD card into the slot.
That was a waste of $5.95!
jeff520
Re: Low profile microSD adapter
by Syn7 on Tue Apr 09, 2013 4:22 am
You should put more thought into your purchases.
Syn7
by Nim on Tue Apr 09, 2013 4:42 pm
Might I suggest investing in a Dremel or some other stupidly-cheap rotary tool? Or just go old school and cut with an Xacto blade.
You're ordering stuff from a Maker site. I assume you must at least have some Maker ability if you are dealing with a Pi. So...MAKE. The low-profile reader doesn't work in the PiBox either, but I fired up my $8 Harbor-Freight rotary tool with a sanding drum and polished that sucker right down (About half way through the thickness of the bottom plate) to where it would fit. And not only does it fit, it looks mostly stock.
Good luck. That adapter is far from a waste, and far worth the effort to make it work.
When you open your mind to the impossible, sometimes you find the truth.
Nim
