Never Give Up
Posts about MIDIsense. open source MIDI sensor platform
Postby adafruit » Fri Nov 02, 2007 5:09 pm
can you measure the dc voltage across C5? (or R13)
Postby WingSpread » Fri Nov 02, 2007 5:31 pm
Ummm ... I don't believe I know how to measure voltage across a Cap.
Do you mean R103? I can't find an R13. In any case the voltage across R103 is 2.56 V DC.
WingSpread
Postby adafruit » Fri Nov 02, 2007 5:33 pm
use a multimeter to measure the voltage across C5 or R13
http://www.ladyada.net/learn/metertut/
not R103
Postby WingSpread » Fri Nov 02, 2007 5:53 pm
The resistance across R13 is 2.56 V DC.
WingSpread
Postby WingSpread » Fri Nov 02, 2007 5:56 pm
voltage, not resistance.
WingSpread
Postby adafruit » Fri Nov 02, 2007 6:18 pm
ah i see your problem
http://www.ladyada.net/make/midisense/makereskit.html
R13 should be a 1K resistor
it is a 10K instead
change the resistor and then see if it works
Postby WingSpread » Fri Nov 02, 2007 7:56 pm
that's better! Now the calibrator goes all the way down to 100.
Still, the big slider does not move. R1, I wonder, the description says 1.5k, but the picture shows brown, black, red (1.0k) ?
WingSpread
Postby adafruit » Fri Nov 02, 2007 8:14 pm
1.0k is fine, ill update the description when i fix up the dox this weekend
so when you have the calibration dialog open the little slider moves back and forth? sounds like you just have to follow the manual on calibration
Postby WingSpread » Fri Nov 02, 2007 8:31 pm
Yes, the little slider behaves very nicely. When I cover the photocell, it moves to the left (lower) and when I lift off my hand it moves to the right.
Quite pleasing.
The manual? You mean:
http://www.ladyada.net/make/midisense/s ... ation.html
WingSpread
Postby WingSpread » Sat Nov 03, 2007 11:17 am
HOT CHA!
It works!!!
Tried it with Logic Pro 8 and it knocks me out.
Thanks and bows from the knees to LadyAda and her supernatural patience.
WingSpread
Previous
Return to MIDIsense
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
cron
