Re: c0nb0x
by antto on Fri Jan 11, 2013 10:29 am
danhillwwr wrote:Hi, I download c0nb0x V 1.00 (MACOSX) it does not work on 10.6.8 ! After two days of hard work, I download c0nb0x 0.99 mac osx and miraculously I had a sign, it work well with snow leopard :D Thank you for this work. PS: sorry for my English rotten :wink:
hi, you shouldn't use v0.99, especially if you will be working on experimental firmwares (v0.99 has a bug which can potentially overwrite the bootloader if you try to upload a big enough .hex file)
for what reason did v1.00 not work?
did the app not start at all, or you just couldn't connect it to the x0x?
antto
Re: c0nb0x
by danhillwwr on Fri Jan 11, 2013 3:45 pm
It was to install the update MarOS 1.4.1 !! Impossible, it does not recognize the usb with V1 (I noted /dev/tty.usb That does not work. I watch your youtube video .
danhillwwr
Re: c0nb0x
by danhillwwr on Fri Jan 11, 2013 4:41 pm
I found , the V1 works 8) "/ dev/tty.usbserial-0000203A " It is a pleasure to the pattern from the software :twisted: ! Thank you for your support :wink:
danhillwwr
Re: c0nb0x
by antto on Sun Mar 03, 2013 8:22 pm
i compiled c0nb0x on linux (thanks to AbortRetryFail for the linux serial port code)
the only downside is that i couldn't figure a good way to set arbitrary baud rate, so it only works with the standard rates which are defined somewhere in termios.h (it'll work with both stock cpu and cpu mod) and there's no serial port detection like there is on the win32 and osx versions, so you have to manually type the path
i discovered another bug, which doesn't show up on the win32 version.. when the app starts, it shows the fancy ascii logo but it should only show it for about 2 seconds then proceed to the main menu
in the linux version - it doesn't timeout, and the logo freezes there till you hit a key - that's the bug, it's clock() from time.h behaving differently on linux/osx
so i switched to using clock_gettime() and it works properly now
i'll probably change the win32 version to use queryperformancecounter() instead of clock() to avoid future trouble
so it smells like i'll have to do this as "v1.01" and so i'd like some feedback
feature requests.. if any
antto
Re: c0nb0x
by Stern on Sat Mar 16, 2013 8:55 am
I'm having a a problem... I got the software to work one single time, I (think I- ) even managed to back up my patterns, but I just can't get it to work again.
I'm on OSX 10.8.3. I installed the com driver, and when I connect the x0xb0x it shows under system information. In terminal is see the port too (tty.usbserial-XXX).
So I put the xoxbox in computer control mode and turn it on. I then load c0nb0x. Two screens load, one empty and one with the computer control splash screen, but nothing happens. Also, I can not quit conbox, I need to force quit it to make it disappear.
What is weird that I had it working once... So what am I doing wrong? Any advice?
Stern
Re: c0nb0x
by Stern on Sat Mar 16, 2013 9:00 am
That's odd... It showed up just now, I guess I was just impatient... But How long does it take for the software to recognize the machine, must have been a more than one minute.
And another (less important?) question, why won't it quit? I need to 'force quit' the app to make it actually shut down.
Stern
Re: c0nb0x
by Stern on Sat Mar 16, 2013 9:30 am
Okay, this is too random... Sometimes it works, sometimes it doesn't and I can't seem to figure out what makes it work and what doesn't.
If someone can shed a light on this I'd appreciate it...
Stern
Re: c0nb0x
by antto on Sat Mar 16, 2013 11:04 am
the OSX version (v1.00) has a bug related to clock() (from time.h) which i discovered a few days ago
the logo screen is supposed to hide automatically after half a second but due to the bug - it gets stuck, you can press any key to continue
as for exiting, it's via the menu, the close button doesn't work
simply hit escape till it quits (that's explained in the readme document)
antto
Re: c0nb0x
by darffader on Mon Mar 18, 2013 8:50 am
Stern wrote:And another (less important?) question, why won't it quit? I need to 'force quit' the app to make it actually shut down.
press any key after pressing quit.
no need to force quit;
darffader
Re: c0nb0x
by SineSurfer on Fri Apr 26, 2013 12:36 am
Hi antto, just to say thanks a lot for your app!
Just used it to upload SokkOS 2 to my x0x and played around with the pattern editor, everything working fine here (OS X 10.8.3) :mrgreen:
Cheers!
x0x 393
SineSurfer
Re: c0nb0x
by Matrix12x on Fri Apr 26, 2013 6:57 pm
The link to the OSX version is no longer working. Can someone send me either a new link or a copy of the OSX version?
Matrix12x
Re: c0nb0x
by antto on Fri Apr 26, 2013 8:19 pm
i ran out of bandwidth on box.com, i released my "soft synth" which i've mentioned a number of times on these forums
it's at kvr it's a win32 VST and approximates the sound of my x0xb0x
it outputs .NSP and .NSM files which can be loaded with c0nb0x
that's why my files there are running very slowly now
Matrix12x: send me an email at <antto-at-mail-d0t-bg> and i'll mail you back the osx version of c0nb0x
antto
Re: c0nb0x
by q-ba on Sun Apr 28, 2013 8:52 am
could you please upload again the c0nb0x 1.0 for windows? box.com doesnt work and cant find it anywhere else
thanks you!
q-ba
Re: c0nb0x
by antto on Sun Apr 28, 2013 3:23 pm
okay, i've setup a little server, the urls in the first post have been updated, you should be able to download now :wink:
antto
c0nb0x on Mac OS 10.7.5
by Chris72160 on Wed May 01, 2013 6:28 am
i`d like to build a x0xb0x and want to use Mac OS 10.7.5.
Does c0nbox V1.0 work with this OS-Version?
Greetz Chris
Chris72160
cron
