I love RPi and I am learning python with it.
I tried the WiFi radio program, but I am not a big fan of pandora, I prefer online radio.
There's a nice project online at http://usualpanic.com that does this. Sheldon, who runs the site and wrote the program is a great guy, but very busy.
I was able to modify the program a little to what I need but I'ts not great, as I mentioned I am learning python.
I am looking for features similar to the pandora radio on RPi but with an external playlist of radio streams.
Sheldon's program shows the name of the station pre-configured in the playlist file.
Many stations show the name of the station and current song info visible in MPC just like with shoutcast and winamp on PC.
I was able to achieve the decoding in python, with this code
f1=os.popen('echo "currentsong" | nc localhost 6600 | grep -e "^Name: "')
f2=os.popen('echo "currentsong" | nc localhost 6600 | grep -e "^Title: "')
firstline = f1.readline()
secondline = f2.readline()
firstline = firstline[6:]
secondline1 = secondline[7:]
It's all great but in the same while loop I am reading the buttons state (the whole program is on usualpanic.com )
and when I continue to display the song and station info the buttons become nonresponsive. I am dealing with this by introducing a countdown to update info every 30 seconds and it works to an extent, when I click a button during the wait time it will change the station but if I click it during the update state it will not change and I have to press again.
In my code when the SELECT button is pressed it will show the full name of the song and in other times only the first 16 characters, again I did this to save some time for the buttons to work.
It's possible to show the whole title either scrolling or line by line divided by 16 charachters but it takes long and buttons do not work then.
If someone is interested here is my (based on Sheldon's program) complete code and the playlist.
#!/usr/bin/python
# radio.py, version 2.1 (RGB LCD Pi Plate version)
# February 17, 2013
# Written by Sheldon Hartling for Usual Panic
# BSD license, all text above must be included in any redistribution
# based on code from Kyle Prier (http://wwww.youtube.com/meistervision)
# and AdaFruit Industries (https://www.adafruit.com)
# Kyle Prier - https://www.dropbox.com/s/w2y8xx7t6gkq8yz/radio.py
# AdaFruit - https://github.com/adafruit/Adafruit-Raspberry-Pi-Python-Code.git, Adafruit_CharLCDPlate
#dependancies
from Adafruit_I2C import Adafruit_I2C
from Adafruit_MCP230xx import Adafruit_MCP230XX
from Adafruit_CharLCDPlate import Adafruit_CharLCDPlate
from datetime import datetime
from subprocess import *
from time import sleep, strftime
from Queue import Queue
from threading import Thread
import os
import smbus
# initialize the LCD plate
# use busnum = 0 for raspi version 1 (256MB)
# and busnum = 1 for raspi version 2 (512MB)
LCD = Adafruit_CharLCDPlate(busnum = 0)
# Define a queue to communicate with worker thread
LCD_QUEUE = Queue()
# Globals
PLAYLIST_MSG = []
STATION = 1
NUM_STATIONS = 0
# Buttons
NONE = 0x00
SELECT = 0x01
RIGHT = 0x02
DOWN = 0x04
UP = 0x08
LEFT = 0x10
UP_AND_DOWN = 0x0C
LEFT_AND_RIGHT = 0x12
# WORKER THREAD
# Define a function to run in the worker thread
def update_lcd(q):
while True:
msg = q.get()
# if we're falling behind, skip some LCD updates
while not q.empty():
q.task_done()
msg = q.get()
LCD.setCursor(0,0)
LCD.message(msg)
q.task_done()
return
# MAIN LOOP
def main():
global STATION, NUM_STATIONS, PLAYLIST_MSG, firstline, secondline, press
# Stop music player
output = run_cmd("mpc stop" )
# Setup AdaFruit LCD Plate
LCD.begin(16,2)
LCD.clear()
LCD.backlight(LCD.ON)
# Create the worker thread and make it a daemon
worker = Thread(target=update_lcd, args=(LCD_QUEUE,))
worker.setDaemon(True)
worker.start()
# Load our station playlist
load_playlist()
sleep(2)
# START THE MUSIC!
# Start music player
run_cmd("mpc volume +100")
last_song = ""
current_song = ""
current_station = ""
last_station = ""
update = 0
i = 6
i1 = 5
line_lenght = 7
line1_lenght = 6
countdown_to_play = 5
delay = 0
mpc_play(STATION)
clearline = (" ")
# Main loop
while True:
press = read_buttons()
if delay == 0:
firstline = (PLAYLIST_MSG[STATION - 1])
secondline2 = secondline[23:]
secondline3 = secondline[39:]
secondline4 = secondline[55:]
secondline5 = secondline[71:]
line2_lenght = len(secondline)
current_song = secondline1
current_station = firstline
if current_station != last_station:
LCD_QUEUE.put(clearline)
LCD_QUEUE.join()
LCD_QUEUE.put(firstline)
LCD_QUEUE.join()
if current_song != last_song:
if (line2_lenght > 0):
LCD_QUEUE.put("\n" + secondline1)
LCD_QUEUE.join()
LCD_QUEUE.join()
LCD_QUEUE.join()
if (line2_lenght == 0):
LCD_QUEUE.put("\n ")
LCD_QUEUE.join()
# LEFT button pressed
while (press == LEFT):
STATION -= 1
if(STATION < 1):
STATION = NUM_STATIONS
LCD_QUEUE.put(PLAYLIST_MSG[STATION - 1], True)
delay_milliseconds(20)
LCD_QUEUE.join()
if press != LEFT:
countdown_to_play = 3
continue
# RIGHT button pressed
while(press == RIGHT):
STATION += 1
if(STATION > NUM_STATIONS):
STATION = 1
LCD_QUEUE.join()
if press != RIGHT:
continue
# UP button pressed
if(press == UP):
output = run_cmd("mpc volume +2")
# DOWN button pressed
if(press == DOWN):
output = run_cmd("mpc volume -2")
# SELECT button pressed
while(press == SELECT):
LCD_QUEUE.put("\n" + clearline)
LCD_QUEUE.join()
if (line2_lenght >= 16):
LCD_QUEUE.put("\n" + secondline2)
LCD_QUEUE.join()
sleep(1)
LCD_QUEUE.join()
if (line2_lenght >= 32):
LCD_QUEUE.put("\n" + secondline3)
LCD_QUEUE.join()
sleep(1)
LCD_QUEUE.join()
if (line2_lenght >= 48):
LCD_QUEUE.put("\n" + secondline4)
LCD_QUEUE.join()
sleep(1)
LCD_QUEUE.join()
if (line2_lenght >= 64):
LCD_QUEUE.put("\n" + secondline5)
LCD_QUEUE.join()
sleep(1)
LCD_QUEUE.join()
LCD_QUEUE.join()
if press != SELECT:
continue
if(countdown_to_play > 0):
countdown_to_play -= 1
if(countdown_to_play == 0):
# Play requested station
mpc_play(STATION)
last_song = current_song
last_station = current_station
update_lcd.join()
# READ SWITCHES
def read_buttons():
buttons = LCD.readButtons()
# Debounce push buttons
if(buttons != 0):
while(LCD.readButtons() != 0):
delay_milliseconds(10)
return buttons
def delay_milliseconds(milliseconds):
seconds = milliseconds / float(1000) # divide milliseconds by 1000 for seconds
sleep(seconds)
# LOAD PLAYLIST OF STATIONS
def load_playlist():
# Run shell script to add all stations
# to the MPC/MPD music player playlist
output = run_cmd("mpc clear")
output = run_cmd("/home/pi/projects/radio/radio_playlist.sh")
# Load PLAYLIST_MSG list
PLAYLIST_MSG = []
with open ("/home/pi/projects/radio/radio_playlist.sh", "r") as playlist:
# Skip leading hash-bang line
for line in playlist:
if line[0:1] != '#!':
break
# Remaining comment lines are loaded
if line[0] == "#" :
PLAYLIST_MSG.append(line.replace(r'\n','\n')[1:-1] + " ")
playlist.close()
NUM_STATIONS = len(PLAYLIST_MSG)
# RADIO SETUP MENU
def run_cmd(cmd):
p = Popen(cmd, shell=True, stdout=PIPE, stderr=STDOUT)
output = p.communicate()[0]
return output
#def run_cmd_nowait(cmd):
#pid = Popen(cmd, shell=True, stdout=NONE, stderr=STDOUT).pid
def mpc_play(STATION):
pid = Popen(["/usr/bin/mpc", "play", '%d' % ( STATION )]).pid
if __name__ == '__main__':
main()
#if secondline != update:
#LCD_QUEUE.put(firstline + "\n" + secondline)
#update = secondline
and the playlist
#! /bin/sh
#1: RMF FM
mpc add http://files.kusmierz.be/rmf/rmf-2.mp3
#2: BEST OF RMF ON
mpc add http://files.kusmierz.be:80/rmf/bestofrmfon-2.mp3
#3: ELO
mpc add http://files.kusmierz.be:80/rmf/elo-2.mp3
#4: RMF 2
mpc add http://files.kusmierz.be:80/rmf/rmf2-2.mp3
#5: RMF 2000
mpc add http://files.kusmierz.be:80/rmf/2000-2.mp3
#6: RMF 3
mpc add http://files.kusmierz.be:80/rmf/rmf3-2.mp3
#7: RMF 4
mpc add http://files.kusmierz.be:80/rmf/rmf4-2.mp3
#8: RMF 5
mpc add http://files.kusmierz.be:80/rmf/rmf5-2.mp3
#9: RMF 50'S
mpc add http://files.kusmierz.be:80/rmf/50s-1.mp3
#10: RMF 60'S
mpc add http://files.kusmierz.be:80/rmf/60s-1.mp3
#11: RMF 70's
mpc add http://files.kusmierz.be:80/rmf/70s-1.mp3
#12: RMF 70's Disco
mpc add http://files.kusmierz.be:80/rmf/70sdisco-1.mp3
#13: RMF 80's
mpc add http://files.kusmierz.be:80/rmf/80s-1.mp3
#14: RMF 80's Disco
mpc add http://files.kusmierz.be:80/rmf/80sdisco-1.mp3
#15: RMF 90's
mpc add http://files.kusmierz.be:80/rmf/90s-1.mp3
#16: RMF Alternatywa
mpc add http://files.kusmierz.be:80/rmf/alternatywa-1.mp3
#17: RMF Baby
mpc add http://files.kusmierz.be:80/rmf/baby-1.mp3
#18: RMF Bealtlemania
mpc add http://files.kusmierz.be:80/rmf/beatlemania-1.mp3
#19: RMF BRAVO
mpc add http://files.kusmierz.be:80/rmf/bravo-1.mp3
#20: RMF Celtic
mpc add http://files.kusmierz.be:80/rmf/celtic-1.mp3
#21: RMF Chillout
mpc add http://files.kusmierz.be:80/rmf/chillout-1.mp3
#22: RMF Chopin
mpc add http://files.kusmierz.be:80/rmf/chopin-1.mp3
#23: RMF Classic
mpc add http://files.kusmierz.be:80/rmf/classic-1.mp3
#24: RMF Classic Rock
mpc add http://files.kusmierz.be:80/rmf/classicrock-1.mp3
#25: RMF Club
mpc add http://files.kusmierz.be:80/rmf/club-1.mp3
#26: RMF ClubBreaks
mpc add http://files.kusmierz.be:80/rmf/clubbreaks-1.mp3
#27: RMF Cover
mpc add http://files.kusmierz.be:80/rmf/cover-1.mp3
#28: RMF Cuba
mpc add http://files.kusmierz.be:80/rmf/cuba-1.mp3
#29: RMF DANCE
mpc add http://files.kusmierz.be:80/rmf/dance-1.mp3
#30: RMF DepecheMode
mpc add http://files.kusmierz.be:80/rmf/depechemode-1.mp3
#31: RMF Electroshockwave
mpc add http://files.kusmierz.be:80/rmf/electroshockwave-1.mp3
#32: RMF Blues
mpc add http://files.kusmierz.be:80/rmf/blues-1.mp3
#33: RMF 20 lat
mpc add http://files.kusmierz.be:80/rmf/20lat-1.mp3
#34: RMF Flamenco
mpc add http://files.kusmierz.be:80/rmf/flamenco-1.mp3
#35: RMF Football
mpc add http://files.kusmierz.be:80/rmf/football-1.mp3
#36: RMF Francais
mpc add http://files.kusmierz.be:80/rmf/francais-1.mp3
#37: RMF Gold
mpc add http://files.kusmierz.be:80/rmf/gold-1.mp3
#38: RMF Grove
mpc add http://files.kusmierz.be:80/rmf/groove-1.mp3
#39: RMF Grunge
mpc add http://files.kusmierz.be:80/rmf/grunge-1.mp3
#40: RMF Hardheavy
mpc add http://files.kusmierz.be:80/rmf/hardheavy-1.mp3
#41: RMF Hiphop
mpc add http://files.kusmierz.be:80/rmf/hiphop-1.mp3
#42: RMF HopBec OldSchool
mpc add http://files.kusmierz.be:80/rmf/hopbecoldschool-1.mp3
#43: RMF Hot New
mpc add http://files.kusmierz.be:80/rmf/hotnew-1.mp3
#44: RMF Lady Pank
mpc add http://files.kusmierz.be:80/rmf/ladypank-1.mp3
#45: RMF Love
mpc add http://files.kusmierz.be:80/rmf/love-1.mp3
#46: RMF Maxxx
mpc add http://files.kusmierz.be:80/rmf/maxxx-1.mp3
#47: RMF HopBec
mpc add http://files.kusmierz.be:80/rmf/hopbec-1.mp3
#48: RMF Ibiza
mpc add http://files.kusmierz.be:80/rmf/ibiza-1.mp3
#49: RMF Michael Jackson
mpc add http://files.kusmierz.be:80/rmf/jackson-1.mp3
#50: RMF MJ
mpc add http://files.kusmierz.be:80/rmf/mj-1.mp3
#51: RMF FILMOWA
mpc add http://files.kusmierz.be:80/rmf/filmowa-1.mp3
#52: RMF KLASYCZNA
mpc add http://files.kusmierz.be:80/rmf/klasyczna-1.mp3
#53: RMF MUZZO
mpc add http://files.kusmierz.be:80/rmf/muzzo-1.mp3
#54: RMF NIEZAPOMNIANE
mpc add http://files.kusmierz.be:80/rmf/niezapomnianemelodie-1.mp3
#55: RMF NIPPON
mpc add http://files.kusmierz.be:80/rmf/nippon-1.mp3
#56: RMF NOSTALGIA
mpc add http://files.kusmierz.be:80/rmf/nostalgia-1.mp3
#57: RMF COUNTRY
mpc add http://files.kusmierz.be:80/rmf/country-1.mp3
#58: RMF PARTY
mpc add http://files.kusmierz.be:80/rmf/party-1.mp3
#59: RMF LITERACKA
mpc add http://files.kusmierz.be:80/rmf/literacka-1.mp3
#60: RMF POLSKIROCK
mpc add http://files.kusmierz.be:80/rmf/polskirock-1.mp3
#61: RMF POLSKIE DISCO
mpc add http://files.kusmierz.be:80/rmf/polskiedisco-1.mp3
#62: RMF POLSKIE PRZEBOJE
mpc add http://files.kusmierz.be:80/rmf/pprzeboje-1.mp3
#63: RMF POPCOLORS
mpc add http://files.kusmierz.be:80/rmf/popcolors-1.mp3
#64: RMF POPLISTA
mpc add http://files.kusmierz.be:80/rmf/poplista-1.mp3
#65: RMF POPLISTA 10LAT
mpc add http://files.kusmierz.be:80/rmf/poplista10lat-1.mp3
#66: RMF PRL
mpc add http://files.kusmierz.be:80/rmf/prl-1.mp3
#67: RMF PRZEBOJ LATA
mpc add http://files.kusmierz.be:80/rmf/przebojlata-1.mp3
#68: RMF PUNK
mpc add http://files.kusmierz.be:80/rmf/punk-1.mp3
#69: RMF QUEEN
mpc add http://files.kusmierz.be:80/rmf/queen-1.mp3
#70: RMF RNB
mpc add http://files.kusmierz.be:80/rmf/rnb-1.mp3
#71: RMF REGGAE
mpc add http://files.kusmierz.be:80/rmf/reggae-1.mp3
#72: RMF ROCK
mpc add http://files.kusmierz.be:80/rmf/rock-1.mp3
#73: RMF PROGRES. ROCK
mpc add http://files.kusmierz.be:80/rmf/progrock-1.mp3
#74: RMF RUMOR
mpc add http://files.kusmierz.be:80/rmf/rumor-1.mp3
#75: RMF SADE
mpc add http://files.kusmierz.be:80/rmf/sade-1.mp3
#76: RMF SMOOTH JAZZ
mpc add http://files.kusmierz.be:80/rmf/smoothjazz-1.mp3
#77: RMF STYL
mpc add http://files.kusmierz.be:80/rmf/styl-1.mp3
#78: RMF SZANTY
mpc add http://files.kusmierz.be:80/rmf/szanty-1.mp3
#79: RMF SLONECZNE PRZEBOJE
mpc add http://files.kusmierz.be:80/rmf/sloneczneprzeboje-1.mp3
#80: RMF WOLD MUSIC
mpc add http://files.kusmierz.be:80/rmf/worldmusic-1.mp3
#81: RMF ZIOM
mpc add http://files.kusmierz.be:80/rmf/ziom-1.mp3
#82: RMF FEST.MUZ.FILM.
mpc add http://files.kusmierz.be:80/rmf/fmf-1.mp3
Sheldon's Site http://usualpanic.com has details on how to use the files.
If maybe someone else has a working program, please post it, or maybe someone is very efficient in Python and can do it in 30 minutes, hopefully to mimic the functionality of pandora radio for Rpi.
Thanks in advance, this project is important to me and hopefully many other's will benefit from it.
-pentiger
