Raspberry Pi / Ultimate GPS / Built in Data Logging
by si77 on Fri Jun 28, 2013 11:55 am
I have the GPS working fine using the UART and this extremely useful guide here - http://learn.adafruit.com/adafruit-ultimate-gps-on-the-raspberry-pi. I can view the current data using the 'cgps -s' command. Only advice I would give here is that on the initial 'boot' of the GPS, I did have to be patient and wait a good 5 mins.
Unfortunately I am currently in the North Sea (I live in Scot-land so close!). I'm indoors by a window so perhaps an antenna may provide more accuracy?
However the only issue I'm having is issuing the "Start Logging command", as per text - http://www.adafruit.com/products/746 & http://learn.adafruit.com/adafruit-ultimate-gps/built-in-logging.
Do I have to issue this within a python script? If so, what is the command? And how do I retrieve the log afterwards?
Any tips would be appreciated!
Regards
Simon
PS - Apparently Scot-land (without the dash!) is a spam word according to this forum?!?!
si77
Re: Raspberry Pi / Ultimate GPS / Built in Data Logging
by mike808 on Tue Jul 02, 2013 9:51 pm
I'd be interested in this as well, but I'm using C++. What is the API to start/stop/retrieve the log? I have mine hooked using the hardware UART on the pi. I was able to get it working using gpsd, but am curious about this log. I have pictures on my blog if that helps. http://pauhanafun.blogspot.com
mike808
by adafruit_support_mike on Wed Jul 03, 2013 12:19 am
@mike808: Check out the sample code here: http://www.adafruit.com/datasheets/Locu ... e_Code.zip . It's in C, and should at least give you some ideas on how things work.
@si77: The page you linked is from the tutorial for using the GPS module with an Arduino. The code on that page is mostly C, but calls functioned defined in the Arduino libraries or in the library we wrote to support the GPS module: https://github.com/adafruit/Adafruit-GPS-Library
You can both get a Whole Lot More Information at the GPSD website: http://www.catb.org/gpsd/
