MAX31855 problem - reads zero
by hb2013 on Thu Jun 20, 2013 5:55 pm
Can't get MAX31855 to read anything other than zero. Below is the code I am using.
#include "Adafruit_MAX31855.h"
int GND = 4;
int VIN = 2;
int thermoDO = 5;
int thermoCS = 6;
int thermoCLK = 7;
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
  pinMode(GND,OUTPUT);
  digitalWrite(GND,LOW);
  pinMode(VIN,OUTPUT);
  digitalWrite(VIN,HIGH);
  Serial.println("MAX31855 test");
  // wait for MAX chip to stabilize
  delay(500);
     if (digitalRead(V3OUT)) {
      Serial.println("MAX31855 V3 IS HIGH");
  // basic readout test, just print the current temp
   Serial.print("Internal Temp = ");
   Serial.println(thermocouple.readInternal());
   double c = thermocouple.readCelsius();
   if (isnan(c)) {
     Serial.println("Something wrong with thermocouple!");
   } else {
     Serial.print("C = ");
     Serial.println(c);
   //Serial.print("F = ");
   //Serial.println(thermocouple.readFarenheit());
   delay(1000);
Last edited by adafruit_support_bill on Thu Jun 20, 2013 7:52 pm, edited 1 time in total.
Reason: Please use the 'code' button when submitting code
hb2013
Re: MAX31855 problem - reads zero
by adafruit_support_bill on Thu Jun 20, 2013 7:53 pm
What thermocouple are you using? Is it grounded? Post a photo or wiring diagram.
by hb2013 on Thu Jun 20, 2013 8:56 pm
Here are the pics. I am using K-type thermo-couple.
hb2013
by adafruit_support_bill on Thu Jun 20, 2013 9:34 pm
Is it grounded?
by hb2013 on Thu Jun 20, 2013 9:57 pm
Do you mean thermocouple? It has two wires connected as shown. Ground what? The probe?
hb2013
by adafruit_support_bill on Fri Jun 21, 2013 5:45 am
If the junction is in contact with a grounded object, it will read 0 with this amplifier.
by hb2013 on Fri Jun 21, 2013 10:37 am
No it is not. It is seating on a wooden surface.
hb2013
by adafruit_support_bill on Fri Jun 21, 2013 11:06 am
Your connections look ok. Contact support@adafruit.com with a link to this thread and we can send you a replacement.
by jerm2119 on Wed Jun 26, 2013 12:42 pm
I have a similar problem. Using the arduino 1.0.5 software and an adruino uno, the serial monitor output is -127.94 Celsius regardless of where the thermocouples are. There is also a message saying "Something wrong with thermocouple!" I've checked the wiring and even if the wires were reversed, that number is not possible at room temperature. Help?
jerm2119
by adafruit_support_bill on Wed Jun 26, 2013 2:09 pm
That sounds more like a problem with the thermocouple than the MAX31855. Where did you purchase these? I don't see you in the customer database.
by paddygoat on Wed Jul 03, 2013 9:00 am
Just recieved my MAX31855 breakout board (invoice no. 303135) and wired it up BUT getting - Int. Temp = -127.94 and T/C Problem BUT I tested the thermocouple on a rocket scream MAX31855 board and it works fine. Please advise .... Thank you.
paddygoat
by paddygoat on Wed Jul 03, 2013 9:11 am
Also, there is a problem finding the avr folder. Just got the board working with the serial version of the software, but quite a few 'thermocouple errors'.
paddygoat
by adafruit_support_bill on Wed Jul 03, 2013 9:32 am
Contact support@adafruit.com with a link to this thread to arrange for a replacement.
by paddygoat on Wed Jul 03, 2013 9:36 am
It's the code that was not working actually. Got it working by replacing with this:
#include <LiquidCrystal.h>
int thermoDO = 3;
int thermoCS = 4;
int thermoCLK = 5;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
lcd.begin(16, 2);
delay(500);
if (isnan(c)) {
} else {
Serial.println(c);
lcd.setCursor(0, 0);
lcd.print("Int. Temp = ");
lcd.println(thermocouple.readInternal());
lcd.print(" ");
lcd.setCursor(0, 1);
lcd.print("C = ");
lcd.print(c);
lcd.print(" ");
delay(1000);
paddygoat
by adafruit_support_bill on Wed Jul 03, 2013 9:43 am
Interesting. The thermocouple part of that code looks identical to the serialThermocouple example.
cron
