I just built a tvbgone recently and am very impressed.
However, there is a problem with the schematic. The 120 ohm resistors are wayyy too small! (It still works fine because the current is limited by the output pin)
To get 100 mA in the LED you only need a 3.3k resistor. The base current would be (3 - 0.7) / 3.3k = 0.7 mA, times the current gain (150) the collecter current would be 105 mA. I tested this with pspice and on a breadboard.
You could get away with more current by using a 1k or 2k resistor.
