Test of cc3000:Sketch sends data using PHP to web server
by sketchy on Fri Sep 20, 2013 6:15 pm
In case this of interest to anyone.
I have been "playing around" with Adafruit's cc3000 in an attempt at growing my knowlege using this chip to send data (some day from many clients) to a web service.
Please help me reach my goal of "getting better" by letting me know how I could write or explain this sketch better.
Testing Connecting to Home Web Server Using cc3000
sketchy
Re: Test of cc3000:Sketch sends data using PHP to web server
by adafruit_support_mike on Sat Sep 21, 2013 2:54 am
The code looks fairly straightforward overall. The only general comment I have is that your indentation is off in this section:
    // Send request
     if (client.connected()) {
       Serial.println("Connected");
       String request = "GET "+ repository + "sensor.php?temp=" + temperature + "&hum=" + humidity + " HTTP/1.0\r\nConnection: close\r\n\r\n";
       Serial.print("...Sending request:");Serial.println(request);
       send_request(request);
  } else {
    Serial.println(F("Connection failed"));
    return;
The `else` clause needs to be shifted over so it's in line with the parent `if` statement.
Beyond that there isn't much I can suggest. The code does its job in simple and understandable terms, which is the main goal.
by adafruit_support_rick on Sat Sep 21, 2013 7:13 am
The Arduino IDE now has an "Auto Format" command in the Tools menu. It works pretty well
by sketchy on Sat Sep 21, 2013 9:06 am
Thank you both. I will fix the indentation and try "Auto Format" (I didn't know it existed - thanks!).
sketchy
