Problems with trinket PWM on pin 4
by andygrove on Tue Sep 24, 2013 11:22 pm
I've created a simple RGB LED "blinky" project using an Adafruit Arduino Trinket (the 5V version) and it is working pretty well (http://www.youtube.com/watch?v=Kz6zIT0sweI) but I haven't been able to get PWM working on pin #4 and could use some help. PWM works fine on pins #0 and #1 though.
I'm using common annode RGB LED from Adafruit also (http://www.adafruit.com/products/302). The annode pin is connected to the trinket's 5V out and the other three pins are connected to digital pins #0, #1, and #4 (each one via a 220 ohm resistor).
PIns #0 and #1 give the expected PWM glowing LED effect but pin #4 is just switching between ON and OFF. I have tried changing which color is connected to pin #4 and the same thing happens so the issue is specific to this pin. I am powering the trinket from a 9V battery when running the code and do not have USB connected (I know pin #4 is shared with USB).
I'd appreciate any pointers on where I am going wrong with this. Thanks in advance.
Here is the sketch that demonstrates the issue:
int pinR = PB0; // Digital pin #0
int pinG = PB1; // Digital pin #1
int pinB = PB4; // Digital pin #4
  pinMode(pinR, OUTPUT);
  pinMode(pinG, OUTPUT);
  pinMode(pinB, OUTPUT);
void set(int rgb[]) {
  set(rgb[0], rgb[1], rgb[2]);
void set(int r, int g, int b) {
  // using common annode LED so low means ON!
  analogWrite(pinR, 255-r);
  analogWrite(pinG, 255-g);
  analogWrite(pinB, 255-b);
int index = 0;
  int rgb[3];
  int d = 20;
  rgb[0] = 0;
  rgb[1] = 0;
  rgb[2] = 0;
  for (int i=0; i<255; i+=5) {
    rgb[index] = i;
    set(rgb);
    delay(d);
  for (int i=255; i>=0; i-=5) {
    rgb[index] = i;
    set(rgb);
    delay(d);
  if (++index == 3) {
    index = 0;
andygrove
Re: Problems with trinket PWM on pin 4
by franklin97355 on Wed Sep 25, 2013 12:37 am
You really should post Trinket questions in the Trinket forum, that's what it was created for.
franklin97355
by adafruit_support_mike on Wed Sep 25, 2013 1:51 am
Moved.
Actually we have another thread about exactly the same issue currently running: viewtopic.php?f=52&t=43572
The short version is that this is a known glitch. The hardware supports PWM on pin4 but we're not sure if the Arduino core has the necessary code. It's on our "things to look at" list.
by mrburnette on Wed Sep 25, 2013 12:25 pm
EDITED:
I use several tiny cores and I compiled the Op's code under the following two cores as noted and then used my scope to double-check the PWM on the three pins. As shown, both compiles when uploaded to the Trinket were successful.
Screen cut&paste of actual command line in bold:
Source: DigisparkArduino-Win32-1.0.4-May19.zip
With Digispark 16MHz core:
avrdude -c usbtiny -p attiny85 -U flash:w:sketch_sep25a.cpp.hex
Results: PWM on 0, 1, 4 verified
Source: https://code.google.com/p/arduino-tiny/ ... 0-0015.zip
ATtiny85 @ 16 MHz (internal PLL; 4.3 V BOD):
mrburnette
by anayar on Thu Sep 04, 2014 1:57 pm
Has there been any update or resolution to this problem? I purchased a Trinket for the sole purpose of making small RGB night light as a gift for someone and it took me forever to realize that it pin 4 was the problem, not my code or wiring. Even if there won't be a solution, I feel like you should make this issue more prominent on the product page rather than buried in a random tutorial.
anayar
by adafruit2 on Fri Sep 05, 2014 4:52 pm
adafruit2
Site Admin
by anayar on Fri Sep 05, 2014 7:27 pm
Great success! Thank you!
anayar
by hiduino on Thu Sep 11, 2014 4:52 am
As an alternative to defining custom PWM4_init() and analogWrite4() functions you could just modify the \variants\tiny8\pins_arduino.h file.
Add the following to the pins_arduino.h file:
#define TCCR1A GTCCR
#define WGM10  PWM1B
Update the line to include TIMER1B for pin 4:
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
   TIMER0A, /* OC0A */
   TIMER0B,
   NOT_ON_TIMER,
   NOT_ON_TIMER,
   TIMER1B,
   NOT_ON_TIMER,
This will allow the Arduino standard core to work with the tiny85 and basically do the same thing as the custom functions but using the standard analogWrite() function call. (Adafruit you should consider making this change in your Trinket variants distribution instead of having users add the custom functions to their sketches. This will help simplify sketches to using standard calls.)
hiduino
by adafruit2 on Thu Sep 11, 2014 5:13 pm
oooo thank you! that's a good idea, we'll check it out!
adafruit2
Site Admin
by tdicola on Thu Sep 11, 2014 11:00 pm
Gave it a quick test and it works great, thanks for suggesting the change!
tdicola
by adafruit2 on Mon Sep 15, 2014 12:26 pm
Yay! thanks for the fix, we updated all the pre-install and hardwaresupport files. so going forward it should automagically work. you can also of course use the older style too. whew!
adafruit2
Site Admin
by hiduino on Thu Sep 18, 2014 5:10 pm
Just to note, the Introducing Trinket tutorial still says pin#4 is not supported for PWM in the programming-with-arduino-ide section.
hiduino
by tdicola on Fri Sep 19, 2014 3:26 pm
Oh thanks for catching that--just updated the page to mention that the latest IDE has support for analogWrite and pin #4. Thanks!
tdicola
by ja450n on Sat Sep 27, 2014 7:24 pm
I was working on a project using PWM on pin 4 to drive a motor and had a common problem of the motor whining and in finding a solution for my problem I may have found a potential bug in the current implementation.
Normally changing the PWM frequency, by doing something like below works:
TCCR0B = TCCR0B & 0b11111101 | 0x01;
The problem is Pin4 doesn't seem to be tied to the available options (TCCR0B, TCCR0A, TCCR1A)
I found that TCCR1B works, but you have to change the pins_arduino.h file to define this.
ja450n
by hiduino on Sun Sep 28, 2014 5:59 am
PWM #4 is using timer1 counter. It uses register TCCR1 (not TCCR1B) for adjusting prescaler frequency. You don't need to define it. It's already defined at part of the ATtiny85 support.
You can use it like:
void setup()  {
  pinMode(4, OUTPUT);
  TCCR1 = TCCR1 & 0b11110000 | ((0<<CS13) | (1<<CS12) | (1<<CS11) | (0<<CS10));
Adjust the bits as needed for the prescale clock you want.
hiduino
