Menta Blues
Menta Blues
by kf4kco on Fri Sep 27, 2013 9:13 am
I tried assembling the menta kit but suspect I have many cold joints. :-(
Photo is on flickr: http://www.flickr.com/photos/kf4kco/9965468675/
kf4kco
Re: Menta Blues
by adafruit_support_bill on Fri Sep 27, 2013 9:17 am
It's hard to see in the photo. It's a bit dark and blurred from camera shake. Try next to a window - or even outside for more light.
A top-side photo would be good too!
Re: Menta Blues
by kf4kco on Fri Nov 08, 2013 3:55 am
Here are the photos
photo 3.JPG (557.94 KiB) Viewed 495 times
photo 2.JPG (502.06 KiB) Viewed 495 times
photo 1.JPG (519.96 KiB) Viewed 495 times
kf4kco
Re: Menta Blues
by adafruit_support_bill on Fri Nov 08, 2013 7:10 am
Are you using lead-free solder? Your joints look well-formed, but have a 'frosty' surface. With 60/40 Lead/Tin solder, that would be one indication of a cold joint. But lead-free solder always looks that way. Does the board work? Do you see any LEDs flashing when you power it up?
Re: Menta Blues
by kf4kco on Fri Nov 08, 2013 9:47 am
I'm using lead-free solder. Would reheating the joints help?
kf4kco
Re: Menta Blues
by kf4kco on Fri Nov 08, 2013 9:48 am
The LEDs do not light up.
kf4kco
Re: Menta Blues
by adafruit_support_bill on Fri Nov 08, 2013 9:51 am
I think your solder joints look fine. If you are using lead-free solder a slightly frosted look is normal. It looks like you have not installed the power jumper. You need that to run the Menta: http://learn.adafruit.com/adafruit-ment ... ble/use-it
Re: Menta Blues
by kf4kco on Fri Nov 08, 2013 2:34 pm
I had the kit in storage and took the jumper out. My concern was about the frosted look. I also have a new soldering pencil which frosts less.
kf4kco
Re: Menta Blues
by adafruit_support_bill on Fri Nov 08, 2013 2:47 pm
So, does it power up OK with the jumper installed now?
Re: Menta Blues
by kf4kco on Mon Nov 11, 2013 12:19 am
No. No blinky. :-(
kf4kco
Re: Menta Blues
by adafruit_support_bill on Mon Nov 11, 2013 7:42 am
How are you powering it? Make sure you have the jumper in the right position. If you are powering via the FTDI cable, make sure you have that oriented properly (it is possible to plug it in backwards).
Do you have a multimeter to take some measurements?
Re: Menta Blues
by kf4kco on Mon Nov 11, 2013 11:50 am
To be clear, I'm only at the point of powering from the battery. I've put the jumper in similar to your photo above. I'm using a 9V battery and the multimeter shows the voltage you'd expect. Since it's only partially, I didn't try using my FTDI+ friends (switching the jumper, of course)
What other measurements should I take?
kf4kco
Re: Menta Blues
by adafruit_support_bill on Mon Nov 11, 2013 12:33 pm
What to expect depends on where you are measuring. What voltages do you measure on each of the 3 pins of the voltage regulator?
Re: Menta Blues
by kf4kco on Fri Nov 15, 2013 3:01 am
It looks like 9v is getting to the regulator but the output is just under 4v--I'd guess 3.7-ish.
kf4kco
Re: Menta Blues
by adafruit_support_bill on Fri Nov 15, 2013 7:57 am
Hmmm. That is well below what it should be. But should still be enough to light the power led. Is anything on the board getting warm?
