Solar charger stops charging at 3.48V
by local_dani_21 on Mon Sep 30, 2013 3:26 pm
Hi
I'm running your solar charger (V2) with your large solar panel and a small 1200mAh lipo-battery. It seems very strange to me that the charger lights the green light (fully charged) very soon - when the battery only has 3.48V.
Do you have any idea what could be wrong? Is it still charging when the green light is on or has it stopped?
Thanks, Dani
local_dani_21
Re: Solar charger stops charging at 3.48V
by adafruit_support_bill on Mon Sep 30, 2013 4:03 pm
Is that the only led that is on?
by local_dani_21 on Mon Sep 30, 2013 4:06 pm
No, the three of them are on (red, yellow, green).
local_dani_21
by adafruit_support_bill on Mon Sep 30, 2013 4:35 pm
That would indicate a temperature fault. Did you install a thermistor to monitor battery temperature?
by local_dani_21 on Mon Sep 30, 2013 5:26 pm
Yes I did install one, 10k NTC as far as I recall.
And I'm running it indoors, normal room temperature.
local_dani_21
by adafruit_support_bill on Mon Sep 30, 2013 5:59 pm
Did you remove the existing 10K resistor from the board?
by local_dani_21 on Mon Sep 30, 2013 6:22 pm
Ups, in fact I didn't - wasn't aware I had to. Thanks for the tipp, I just removed it and am trying to load the battery. For others to read this post: Look closely at: http://learn.adafruit.com/usb-dc-and-solar-lipoly-charger/using-the-charger
Thanks, Dani
local_dani_21
