Green LED only flashing once
Get help and show off your TV-B-Gone kit!
Postby DrRobb » Mon Jan 21, 2008 5:23 pm
Just finished my kit and during the testing phase I didn't realize that the green LED was supposed to continue flashing throughout the cycle. My LED flashes once and quits.. Examining the LED through a digital camera confirms that the IR LEDS also only flash once.. Is this a bad flash on the preprogrammed chip or something else? Just looking for someone to point me in the right direction..
DrRobb
Postby adafruit » Mon Jan 21, 2008 6:21 pm
do you have good alkaline batteries?
Single Flash Only
Postby hopperomatic » Tue Jan 22, 2008 9:30 am
I seem to be having the same problem... I think.
I get one green flash only when I hit the reset button. Checking the IR LEDs through a camera viewfinder confirms that they all flash only once, too.
Brand new batteries showing good strength on my MM.
Just to make sure, I've tried the device on 1/2 dozen U.S. TVs to no avail.
hopperomatic
Postby DrRobb » Wed Jan 23, 2008 1:56 pm
Update..
Put in new fresh batteries.. The first set was unused but old.. They showed full voltage, but must have been weak under load.. New batteries worked perfectly..
DrRobb
Postby adafruit » Wed Jan 23, 2008 3:30 pm
great, thanks for the note. the tvbgone needs a lot of power, and if the battery voltage dips, it will reset.
good to hear you got it working
hopper can you try the same thing?
oops!
Postby hopperomatic » Wed Jan 23, 2008 7:24 pm
My bad. One of my old batteries snuck into my new bulk battery purchase pile.
The problem was, in fact, fixed by putting in fresh batteries.
What's the max voltage I can send to the kit? I see you've OK'd 4.5V, but how about 5V?
I've read your arguments against using 9V over AA here:
http://www.ladyada.net/make/mintyboost/process.html
...but will I get more lifetime with the same footprint if I use a 9V with a 5V regulator (I have a bunch of these)? My dysfunctional AA combo was putting out 2.7V and it was resetting, so I'm inclined to go higher voltage accepting the inefficiencies that I'll get with a 9V and regulator, or is this more about mA output?
If I need to be schooled in electricity, please just send me a link instead of a reply :-)
hopperomatic
Postby adafruit » Wed Jan 23, 2008 7:56 pm
5V is the max. you will still get a lot more life from AA's than 9V, even without a boost converter. for max life and max distance, use 3 high quality alkalines AAs!
Return to TV-B-Gone Kit
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
