Nooby Python folders question.
by Krisduck on Fri Oct 25, 2013 1:39 am
This feels like a silly question, but I'll ask anyway.
After installing my LED Backpack and finally getting my clock working the way I want, I'm left with one minor annoyance.
The library installed to /home/me/Adafruit-Raspberry-Pi-Python-Code/Adafruit_LEDBackpack but all my other python scripts are in /home/me/. If I copy the clock.py file to /home/me, it complains about not finding the proper files. My other scripts don't have a problem being in the home folder. Can I move the Adafruit files somewhere that it can find them? In searching, people talk about changing the default paths and stuff, it just shouldn't be that complicated... or should it?
Thanks in advance,
Kris
Krisduck
Re: Nooby Python folders question.
by adafruit_support_mike on Fri Oct 25, 2013 12:14 pm
It isn't particularly complicated, it's just a matter of providing enough information. If I were to say, "libraries work just fine where I put them", your obvious response would be, "yeah, but where do you put them?"
The Python interpreter has basically the same problem when you run a script that wants to import an external file. It's smart enough to look in the same folder as the script itself, then has a list of other folders to check if that doesn't work. If you don't want to store files in any of those places, you need to tell it the location you've chosen.
by Krisduck on Sun Oct 27, 2013 11:20 pm
adafruit_support_mike wrote:It isn't particularly complicated, it's just a matter of providing enough information. If I were to say, "libraries work just fine where I put them", your obvious response would be, "yeah, but where do you put them?"
I DO want to store them where it defaults to looking. Installing the Module put it in my home folder, not one of the python module folders. Every other python module I've installed seems to place the libraries somewhere I can access them. Can I move the Adafruit Backpack module there too? Or do I just point to the folder in the script?
Thanks again.
Krisduck
by Krisduck on Tue Oct 29, 2013 11:38 pm
After some more searching, I came across the suggestion including the sys.path.append addition. Though I seem to be doing it wrong again..
import time
import datetime
import os, sys
CURRENT_DIR = os.path.dirname(os.path.abspath('home/raspberrypi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_LEDBackpack'))
sys.path.append(os.path.dirname(CURRENT_DIR))
from Adafruit_7Segment import SevenSegment
This gives me an error "ImportError: No module named Adafruit_7Segment". I tried including an __init__.py in the folder as per someone's suggestion, but I'm obviously missing something important here.
Thanks again.
Krisduck
by adafruit_support_mike on Wed Oct 30, 2013 4:53 am
All you need is:
sys.path.append("/home/me/Adafruit-Raspberry-Pi-Python-Code/Adafruit_LEDBackpack")
cron
