issue SOLVED, user error. thanks ladyada!
Posts about MIDIsense. open source MIDI sensor platform
Postby nym » Mon Jan 28, 2008 6:03 pm
built my midisense, powered it up to see the leds (power and midi, once i plugged in the UNO)
connected to version 1.3 without a hitch
(small question: why when i open midisense does the DIGITAL I/O column dwarf the entire span of the app? i have to click and drag the middle bar to be where it should be to look like it does on the website. without fail every time i open midisense the analog column is scrunched all the way to the left)
second question - say we're putting a sensor into analog 1. from the RIGHT to LEFT, it goes OUT, IN, GROUND, as per silkscreen, correct?
so i've got an IR sensor in analog1. whenever i click the checkbox on Analog I/O 1, digital 2 gets checkmarked instead.
using the IR and/or the included potentiometer also sometimes yielded this message:
Failed to write sysex message! portmidi: 'invalid midi message data'
also, suddenly, though this was NOT the case when i was testing the power supply earlier, the heatsink is HOT, and the infrared sensor is HOT HOT HOT.
what do i need to do?
also, when attempting to use the included potentiometer, the same issue occurs minus the heat
nym
Postby nym » Mon Jan 28, 2008 6:04 pm
clicking different non-active analog i/o checkboxes results in an always different pattern of check-boxes in the digital i/o column...
nym
Postby nym » Mon Jan 28, 2008 6:20 pm
and last, after updating the firmware to midisense-res11-full.hex successfully, i am no longer getting activity light from my midi LED (though it flashed red while updating)
now that i've successfully backed into a corner, could i get a hand out?
nym
Postby adafruit » Thu Jan 31, 2008 2:21 pm
man, i dont know what you did there :) did you program the ADIO board with the Resistive board firmware?
Try downloading v1.3 of the software from the midisense page, then also download v1.3 of the ADIO firmware, and try to repair your board by uploading the firmware again.
http://www.ladyada.net/make/midisense/u ... grade.html
Postby skelo » Fri Feb 01, 2008 3:17 am
come on
skelo
Postby nym » Fri Feb 01, 2008 9:44 am
updated and installed v1.3, verified and everything is good
i then attempt to connect to midisense so i can RESET
however, i still cannot connect to midisense.
nym
Postby nym » Fri Feb 01, 2008 11:00 am
tried on multiple computers, with multiple usb-midi cords (uno and a turtle beach audio one). though firmware is updated and verified, Midisense still can't be found by the computer. no sensors are plugged in.
the midi LED flashes when i turn on Midisense
when i turn OFF midisense, the POWER light stays on SEMI-LIT when a midi cord is connected to MIDI OUT
nym
Postby soapdodger » Fri Feb 01, 2008 12:19 pm
you have your midi leads the wrong way round if the power led is staying on.
its been mentioned here before
good luck!
soapdodger
Postby nym » Fri Feb 01, 2008 1:01 pm
just checked, my midi cords are connected correctly
nym
Postby adafruit » Fri Feb 01, 2008 1:05 pm
nym wrote:updated and installed v1.3, verified and everything is good
did you re-upload the adio firmware? i
Postby nym » Fri Feb 01, 2008 1:15 pm
yes, both the PC software and the hex file.
i ONLY get light from the midi in/out LED when i turn midisense on OR when i'm upgrading the hex.
nym
Postby adafruit » Fri Feb 01, 2008 1:23 pm
if you turn on the midisense without midi cables, what does the LED do?
Postby nym » Fri Feb 01, 2008 1:25 pm
it flashes: green, red, green, blank. it then stays blank until reboot.
nym
Postby adafruit » Fri Feb 01, 2008 1:27 pm
erm it doesnt sound like you uploaded the firmware since its just in the bootloader.
run debugview (google for it)
and then while you upload and verify firmware, look at what the debug output says and then put it in a text file somewhere online (dont paste it here it will be too long)
Postby nym » Fri Feb 01, 2008 1:57 pm
nym
Next
Return to MIDIsense
Users browsing this forum: mibignistinly and 2 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
