built my midisense, powered it up to see the leds (power and midi, once i plugged in the UNO)
connected to version 1.3 without a hitch
(small question: why when i open midisense does the DIGITAL I/O column dwarf the entire span of the app? i have to click and drag the middle bar to be where it should be to look like it does on the website. without fail every time i open midisense the analog column is scrunched all the way to the left)
second question - say we're putting a sensor into analog 1. from the RIGHT to LEFT, it goes OUT, IN, GROUND, as per silkscreen, correct?
so i've got an IR sensor in analog1. whenever i click the checkbox on Analog I/O 1, digital 2 gets checkmarked instead.
using the IR and/or the included potentiometer also sometimes yielded this message:
Failed to write sysex message! portmidi: 'invalid midi message data'
also, suddenly, though this was NOT the case when i was testing the power supply earlier, the heatsink is HOT, and the infrared sensor is HOT HOT HOT.
what do i need to do?
also, when attempting to use the included potentiometer, the same issue occurs minus the heat
