I am using Adafruit's Assembled Data logging shield for Arduino.
Is it possible to change the chip select pin from pin 10 (I am using an Arduino Uno)? If so, what are the steps to do so?
change chip select on Assembled Data Logging Shield?
- sketchy
- adafruit_support_bill
Re: change chip select on Assembled Data Logging Shield?
Yes. You can cut the trace between pin 10 and the adjacent breakout hole. Then you can run a jumper from the hole labeled "CS" to any other pin.
