Hi! Being a noob to the hardware level of electronics, I've been working thru the tutorials and trying a few projects outside.
My current (hah!) problem is that I've got an LM34DZ temp. http://www.national.com/ds/LM/LM34.pdf sensor hooked up. I've got the VS 5+V with the Vout going straight into the analog 1 pin. The ground also goes straight into the ground connect as well.
After looking at the spec sheet, the variation is 10mV/F degree. however, reading into the analog pin, I'm getting 1020 mV, making it a scorching 102F degrees! I've let the thing have plenty of time to adjust, so i'm wondering what I am doing wrong! Thanks in advance and the tutorials rock!
