Will SpokePOV work on my motorcycle??
SpokePOV kit for bikes
Postby rodelu » Wed Mar 05, 2008 10:03 pm
Been thinking about building a SpokePOV. I'd like to use it on my motorcycle.
Do you think it could work. If not, why?
Thanks.
rodelu
Postby kayrock66 » Thu Mar 06, 2008 12:43 am
This has been a popular question, and asked a couple times. Some of the answers have been that the speeds that you ride a motorcycle would make it unsafe to connect a weight like this to the wheel, both for vibration and as a missile should it come loose. Or another comment has been that the "man" will hassel you for illegal lights, whereas you usually don't get hasseled by the "man" for riding your bicycle. I say its free country and warned ye be says I.
kayrock66
Postby rodelu » Thu Mar 06, 2008 12:50 am
I'm not so much worried about the "man" :) or it flying off - I think I can tie it down safely - I was more concerned about whether it would work if it's going around so fast. Or does speed in RPMs not matter?
Thx
rodelu
Postby mikeyp » Fri Mar 07, 2008 9:11 am
It should work fine, the microcontroller is more than powerful enough afaik.
Even if you can tie down the spokpov firmly enough, I don't fancy the idea of going to the emergency room with a duracell lodged somewhere in my jaw...
mikeyp
Postby rodelu » Fri Mar 07, 2008 11:30 am
mikeyp wrote:It should work fine, the microcontroller is more than powerful enough afaik.
Ha ha! Point taken. Maybe I'll experiment with it on my bike first.
I do have a full face helmet though :)
rodelu
Postby darus67 » Fri Mar 07, 2008 12:59 pm
Other people around you may not.
"He's just this guy. You know?"
darus67
Postby mikeyp » Sun Mar 09, 2008 4:45 pm
rodelu wrote:Ha ha! Point taken. Maybe I'll experiment with it on my bike first.
Ever tried taking a bullet to the helmet since it'll be travelling around the same speed...
And what about the softer more delicate bits of you? lol
mikeyp
Postby chuni959 » Thu Apr 17, 2008 1:40 am
30 miles per hour = 44 feet per second
.22 rimfire cartridge 1200 - 1500 fps
.22 centerfire cartridge 2400 - 3000 fps
.22 Swift 4000 fps
.38 Special 600 fps
.221 Fireball 2650 fps
mikey = absolutely horrid at math
if your a dipshit and somehow magically end up DIRECTLY in the path of the spoke POV circuit board (This would involve an invisible fork scenario), you are looking at dealing with a minor scratch, unless you are lance banned armstrong with mini jetpacks attached to each foot and have god mode on
chuni959
yes
Postby cdfps » Mon Aug 11, 2008 10:14 pm
Works to 45 mph which is all I am really willing to go with a a flathead with drum brakes anyway.
The hard part is getting the software straightened out to work with the smaller "BMX" wheels.
Maybe the question is how fast can a properly strapped down spokePOV run without the batteries flying off.
On could always put the spoke POV units on the rear wheel of an older BMW (who's speedometer reads off of the rear wheel) put it on the center stand and run it up until the batteries fly off.
My guess, 60mph+
Now at least there is an answer to 45mph. If I go any higher without getting leveled by a flying energizer (ray-o-vac alkalines) I will post it, but I tru and keep it around 45.
cdfps
Postby mooseheadm5 » Wed Aug 20, 2008 8:56 pm
This is the very reason I found the lady in the first place.
I would do the following:
Add a waterproof conformal coating
Do away with the batteries and use a slip ring (brushes or some such) to give it _regulated_ power from the bike's charging system
Wire it permanently on and put the on/off switch inline with the power supply wiring
All of this would make it permanent, waterproof, safer, easier to use, and have a lower moment of inertia so it would upset wheel balance less. Not sure if I want to be the first to do this, as I am spread pretty thin with projects (cars, motorcycle, house, Megasquirt, superchargers, 2 jobs, etc.) so let me know how it turns out!
mooseheadm5
Return to SpokePOV
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
