Anyone measured power output of their bubble?
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Postby MightyGuru » Fri Mar 28, 2008 10:06 am
UPDATE
I have replaced the ROS-2500+ with a ROS-2230-119+. With the added 4.5db output of this new VCO my 1900 band output has increased to ~220mW. I am also running SXB-4089Z's on both stages. My 800 band output is at ~400mW now.
Obviously the biggest drawback now is heat and current. The unit is drawing about 1.2A from the battery.
MightyGuru
vcos
Postby inh » Sat Mar 29, 2008 4:04 pm
Hi mightyG - I've been testing those vcos too. would you be able to take a photo of what you have? with an indication of what the component values are?
your results are good...
thanks
Ian
inh
Re: vcos
Postby MightyGuru » Sun Mar 30, 2008 10:10 pm
inh wrote:Hi mightyG - I've been testing those vcos too. would you be able to take a photo of what you have? with an indication of what the component values are? your results are good...
The passives are shown in the datasheet for the SXB-4089Z.
MightyGuru
interesting
Postby inh » Mon Mar 31, 2008 7:15 am
Hi MightyG - very interesting. I note:
1- on the IF side you have the 1ohm (is that the value as per datasheet?) resistor before rather than after the c6/c5 input caps. I assume the WB post vco preamp signal also suffers some attenuation from the siphoning off to the PLL...
I get repeated transistor blows here when using values under 18 ohms ... (but not always!)
2- I tried replacing c5 (1.2pF) called c40 in the WB with 2.7pF on the RF side, between the vco and the transistor, and got a big power increase...
of course it may be a power increase too far with the 2230-119, but the SXB does claim to be capable of 500mA!
thanks
Ian
inh
Re: interesting
Postby MightyGuru » Mon Mar 31, 2008 8:37 am
inh wrote:Hi MightyG - very interesting. I note:
1. I am not using the 1 Ohnm resistor specified in the datasheet. The resistor following the VCO is 18 Ohm. This is for attenuation. I would get frequent tuning errors otherwise.
2. I might have to try the 2.7pF mod. I am still well under the 1/2W output on the 1900 side.
Would you mind posting a picture of your output/gain stage? I'm always interested in how others are placing the passives.
MightyGuru
pics
Postby inh » Mon Mar 31, 2008 4:06 pm
Hi MightyG - I actually have about 12 different variations running successfully and unsuccessfully at the moment, so I need a bit of time to organise what to show you, but yes I will post pics. I'm flying to San Francisco shortly until 15th, so there may be a delay.
I will post though. I've been speaking to Sirenza at great length about these transistors, so have a few perspectives, including 2 different versions of my homemade boards - built to Sirenza specs...
thanks
Ian
inh
pics
Postby inh » Mon Mar 31, 2008 5:26 pm
sorry to be so dumb MightyG - I just took some jpegs of my passives and boards, but I can't work out how to upload them - how do you do it?
thanks
Ian
inh
Re: pics
Postby MightyGuru » Mon Mar 31, 2008 10:13 pm
inh wrote:sorry to be so dumb MightyG - I just took some jpegs of my passives and boards, but I can't work out how to upload them - how do you do it?
I upload/host them at http://www.imageshack.us/ . It is a free image hosting service. I then take the link provided by imageshack and put it in the post with the Img tag.
MightyGuru
Postby powerpants » Mon Apr 14, 2008 11:46 pm
I measured my output today. Here's what I got. I've got a standard by-the-schematic build. I'd appreciate it if somebody would tell me if these numbers are about right for a stock build!
For the ROS-1700
~17.5dBm/50mW
For the ROS-2500
~11.5dBm/12mW
(This one seems a bit low, but there's no shorts across my SXA.....)
powerpants
Postby powerpants » Thu Apr 17, 2008 4:38 pm
anybody?
powerpants
low
Postby inh » Fri Apr 18, 2008 2:31 am
low end of range, particularly for the rf side...
thanks
Ian
inh
Postby powerpants » Fri Apr 18, 2008 8:47 am
That's with full attenuation from the schematic....I wanted to get a reference design working before I start playing with the values - if my results are low, even for full attenuation, what could be causing this low power?
powerpants
power
Postby inh » Fri Apr 18, 2008 9:59 am
microwave design is a black art
http://www.microwaves101.com/encycloped ... fthumb.cfm
this link will start you understanding where your losses are, microwaves and the rf sections of the wb can be thought of as almost optical cavities, with reflections and transmissions similar to those of light. I have a theory that impedance matching is comparable to matching the refractive indices of different light transmitting materials.
a lot of trial and error, with some ideas about wavelengths, solder joints, stripline transission line theory will help.
have fun - it is very weird stuff...
thanks
Ian
inh
Postby andyman » Sun Jul 20, 2008 12:44 pm
MightyGuru
I've got very good results on my 800-900mhz side of things using the passives as specified in the 4089 data sheet but on the 1.9ghz side its just horrible. Can you post pix and some details on what you did on this side? I'm still using the stock VCO's.
andyman
Previous
Return to Wave Bubble
New Products [103]
LEDs[109]
Cables[61]
