Com problems again
Com problems again
Postby richile » Tue May 06, 2008 10:43 am
I had the stepper motor running fine. Disconnected motor to check resistance then reconnected. Did not run and then I tried to ulpoad to board (several times) when I received this error:
avrdude: stk500_recv(): programmer is not responding
I have not changed the usb (checked it) tried all of the other trouble shooting suggestion, also quit app and restart computer to no avail.
Any possible resolutions?
richile
Postby trialex » Tue May 06, 2008 7:03 pm
Sounds like the chip got corrupted - easy to do when connecting various loads to pins.
Have you got a programmer to re-flash the bootloader?
trialex
Postby adafruit » Tue May 06, 2008 7:19 pm
i would unplug the motor shield
power down, then make sure you're powering the board properly
and try again
Postby richile » Wed May 07, 2008 1:59 pm
ladyada wrote:i would unplug the motor shield
and try again
Done that Many times and no response.
richile
Postby richile » Wed May 07, 2008 2:01 pm
trialex wrote:Sounds like the chip got corrupted - easy to do when connecting various loads to pins.
No programmer should I get a new AtMega? Where do I get the bootloader from?
richile
Postby adafruit » Wed May 07, 2008 2:44 pm
never heard of a motor frying the bootloader so im wondering whats up. regardless you can burn your own bootloader if you have a chip programmer or i have them in the adafruit.com shop
Postby richile » Wed May 07, 2008 5:15 pm
ladyada wrote:never heard of a motor frying the bootloader so im wondering whats up. regardless you can burn your own bootloader if you have a chip programmer or i have them in the adafruit.com shop
I have ordered a new ATMega. They are already burned with a bootloader, right? I thought that this might be a less expensive solution. Do you think that this will work?
richile
Postby adafruit » Wed May 07, 2008 8:25 pm
it depends on where you ordered the atmega from
Postby richile » Thu May 08, 2008 10:10 am
Adafruit
richile
Return to Arduino Shields from Adafruit
Users browsing this forum: mibignistinly and 10 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
