USB boarduino soldering instructions?
Postby Matt » Tue May 20, 2008 7:43 pm
I just noticed that there are not any soldering instructions for the USB Boarduino. Are the instructions going to be posted by the time the kits are back in stock?
Matt
Postby adafruit » Tue May 20, 2008 8:29 pm
ya i need to fix the bug in the usb boarduinos and put up instructions
note that its like 99% the same as the DC boarduino... :)
Postby cmpalmer » Tue Jun 03, 2008 1:15 pm
Nothing tricky in the other 1% I hope? I think my USB Boarduino kit is either waiting for me at home or coming tomorrow :)
cmpalmer
Postby adafruit » Tue Jun 03, 2008 2:38 pm
there are fewer parts :) so its really easy...
i will get to putting up instructions soon. arrgh
Postby cmpalmer » Mon Jun 09, 2008 4:37 pm
I assembled my USB Boarduino last night. Nothing too tricky. In fact, I found it much easier to refer just the parts list instead of the step-by-step instructions and just to use a little common sense on the order to put things on.
cmpalmer
hints (until sloldering instructions are up)
Postby KI6RRX » Wed Aug 20, 2008 9:28 pm
in lieu of assembly instructions, the parts list will clarify which components go where. the only part i missed was the jumper, which is labeled 'PWR' on the pcb just behind the usb connector. the photo can be referred to in a pinch.
yes, all the info one needs is there, assuming an intermediate level of experience or better. but there are a few head-scratchers if you try to put it together w/o using the parts list or photo.
KI6RRX
Slab City, CA
chasterus.org
KI6RRX
Re: USB boarduino soldering instructions?
Postby IPFreely » Sun Jun 14, 2009 8:29 pm
For others that wind up seeking this thread:
As the poster above said, the power jumper may not be obvious. I'm fairly technically inclined and I missed it. I just assumed it was designed in for some future use. Of course, when my board wouldn't light up like everyone else's I became suspicious. Gotta connect it.
For noob builders, your best bet is to use the parts list and extrapolate where they all go. If you go by the DC tutorial, note that d1 was eliminated on the usb version so d2 becomes d1 and d3 becomes d2. Also note that the six pin piece that goes by the reset button has the long pins up so you can jumper them. (still havent figured out what to use those for tho)
Seems like a little photo copy of a populated board and a few relevant notes would be included but I guess that would make it too easy... Just pretend you went to banned and enjoy puzzles. Dont stress!
IPFreely
Postby karlgg » Mon Jun 15, 2009 1:40 am
The "six pin piece" is not for jumpering, but to plug an ISP (In-System Programmer - such as the Adafruit USBtinyISP) into.
I think I am, therefore I am... I think.
karlgg
Postby IPFreely » Wed Jun 17, 2009 5:39 pm
Oh, I definitely missed that little factoid lol. Thanks for clearing that up.
IPFreely
Postby jswilson64 » Tue Jun 23, 2009 10:41 pm
I just finished (finally) soldering mine up, and notice there are some unpopulated holes. One is right by the 4 in the C4 silk screen, and there are 3 under the large socket. Did I miss something? I sure hope not...
jswilson64
Postby karlgg » Wed Jun 24, 2009 2:42 am
I'm not familiar with the "USB" version of the Boarduino, but it sounds like those are just vias: pass-throughs to electrically connect a circuit trace on the top side to one on the bottom side. Are they a wee bit smaller than the other (soldered) holes?
karlgg
Postby jswilson64 » Wed Jun 24, 2009 8:09 am
Yes, and the pads are smaller, too.
jswilson64
Postby adafruit » Wed Jun 24, 2009 9:44 am
yup those are vias, they're too small for parts, they're used to pass electricity thru the PCB
Postby troynall » Wed Jul 08, 2009 12:05 pm
not to be a total newb, but I would prefer the soldering instructions.
and i am missing the R1 10k ohm 1/4w 5% resistor ? (BROWN,BLACK,ORANGE,GOLD)
or am i ? is this another "overlooked" part that is not needed but included in the online
parts list ?
also
I purchased the USB boarduino (Arduino cloine) kit w/ATmega328
and a usb cable.
will i need anything else to communicate/program this thing ?
troy:)
troynall
Postby adafruit » Wed Jul 08, 2009 12:54 pm
if you didnt receive a 10K resistor at all then its missing
the good news is...its not actually necessary :)
try building it without the 10k
it will work fine. with just the usb cable
Next
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
