Green & Cream X0xb0x Finished.
x0x0x0x0x0x
Postby GoldDope » Sun Jun 22, 2008 5:10 pm
Well,
eventualy !!
My first ever electronics project,i was realy,realy carefull building this,i double checked every single solder joint,double checked nothing was touching,and spent a lot of time on the case and fascia,
I wanted to add the bass boost mod but the capacitors i got were the wrong ones,. i wanted to do the resonance boost mod but this conflicted slightly with Mome Raths suggestion to change r97
I did however complete the power switch mod,
powered the synth up and bingo,., beautifull and lovely.
This is a self sourced parts kit,using rare parts from Gaetano,
Parts from Mouser and Digikey,
eeprom and fascia from here,
with some good help, tips and advice from Phono,
This was my first ever kit and to be hones i found it easy.
ill add some video tomorow,right now im worn out :)
Heres the Green & Cream X0xb0x :
Thing is,this x0xb0x is photophospherescent :)
it glows in the dark,ill post some pics of it in the dark tomorow ;)
and heres the full build in pictures :
http://v7music.com/artists/bands/1/photo.php :D
GoldDope
Postby Computer Controlled » Sun Jun 22, 2008 6:24 pm
Wow, pretty cool! =o]
Synths: SH-1 . SH-101 . TB-303 . JX-3P . x0xb0x . uWave II . Alesis Ion . Pro-One w/Synthwood case . MoPho . Monotron
Drum Machines: TR-707 . R-70 . E-MU Procussion
Computer Controlled
Postby overfiendau » Sun Jun 22, 2008 7:45 pm
everything is made better by glowing in the dark.
great work
overfiendau
Postby phono » Mon Jun 23, 2008 1:56 am
congrats, its been a long journey for you :) nice to see you took your time and got it right...sound clips? :D
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Postby GoldDope » Mon Jun 23, 2008 2:00 am
overfiendau wrote:everything is made better by glowing in the dark.
great work
lol,well . . . .
a few years ago i had a habit of leaving gear on the floor when i went to bed,
at least if i do i wont step on it ;)
GoldDope
Postby GoldDope » Mon Jun 23, 2008 2:01 am
phono wrote:congrats, its been a long journey for you :) nice to see you took your time and got it right...sound clips? :D
it has been a long road Phono,and im planning to do a few more if i can get the parts,
im def doing some clips today,. only thing is i cant find ANY info on how to program a pattern ?
it works sweet in random mode lol
GoldDope
Postby phono » Mon Jun 23, 2008 2:04 am
heh thats simple
put it in any pattern mode, chooe the bank and pattern to edit, then press next, then press a note (add accent slipe up or down here also) press next again add another note etc, press done when you like at step 1 or 16, this sets the length of the patern. Start the seq :)
Its not so hard, also you might want to think about sokkos, since you can do that in realtime then, which is pretty cool
phono
Postby GoldDope » Mon Jun 23, 2008 2:21 am
ha,got that now thnks Phono :)
its running well,.
i have noticed tho mines a little bit noisier than some of the sound clips ive heard here,theres a little bit of white after each note -
im not realy fussed about that tho,but its there,is this common ?
* edit ,the little noise is only over headphones,so alls well ;)
phono wrote:heh thats simple
GoldDope
Postby GoldDope » Mon Jun 23, 2008 4:26 am
GoldDope
Postby phono » Mon Jun 23, 2008 5:11 am
is the sound unsynced? also some do you have some res boost?
phono
Postby GoldDope » Mon Jun 23, 2008 5:27 am
phono wrote:is the sound unsynced? also some do you have some res boost?
the sound is a little out of sync yeh,. i recorded the audio at 96khz seperaterly,. ill have another go at syncing them together ,
the res boost ?
no.,
the only interenal modification is mome raths :
r46 = jumper / r97 = 8.2k
why do you ask ? :(
GoldDope
Postby phono » Mon Jun 23, 2008 5:35 am
that is a res boost :lol:
i asked cos it sounded a bit whistly at the top of the res, the 8.2k explains what im hearing, you didnt put it on a switch then?
phono
Postby GoldDope » Mon Jun 23, 2008 6:02 am
phono wrote:that is a res boost :lol:
nahr,
cos i can just minimise the resonance by the knob :) i was gonna do loads like the bass boost - you should see the capacitors i got lol,. like little square red sweeties.., :( so i didnt do it.
im just re-doing the video now ;)
* noticed - midi in doesnt work :(
** sorted video.
GoldDope
Postby phono » Mon Jun 23, 2008 1:16 pm
check the troubleshooting faq, 150 ohm resistor needed to fix that
phono
Postby GoldDope » Mon Jun 23, 2008 1:23 pm
phono wrote:check the troubleshooting faq, 150 ohm resistor needed to fix that
cheers ,but its worse - midi out is dead too,.
GoldDope
Next
Return to General x0xing
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
