Reader connection problems
Talk about the videos and projects (SIM reader, payphones...)
Postby Myrmidon » Thu Jul 31, 2008 10:03 am
Hello all.
Just homebrewed the sim reader and i have the device connected up, i'v tried com port 4 and 5 of my laptop but i get this error on both occasions:
File "pySimReader.py", line 267, in buttonConnectReader
File "pySIMserial.pyc", line 111, in connectReader
File "pySIMserial.pyc", line 158, in openSession
TypeError: ord() expected a character, but string of length 0 found
Any ideas?
I'm using the windows pysim and a usb to serial cable with all drivers installed.
Myrmidon
Postby adafruit » Thu Jul 31, 2008 4:05 pm
it means either your sim reader is not assembled/functioning correctly
or
your sim card is broken
Postby tc » Fri Aug 01, 2008 11:22 pm
I get the same error. I don't see any prob with the assembly it looks exactly like the picture. Tried 2 diff sims same error with each.
tc
Postby adafruit » Sun Aug 03, 2008 11:46 am
make sure its powered
make sure its not the serial cable
make sure its the right COM port
if you can post a very clear photo showing the top and bottom of the kit it would be useful to debug
Postby tc » Sun Aug 03, 2008 7:33 pm
Was the cable. I grabbed it from work. I think it was for a UPS so maybe it wasnt normal. Got a usb-serial cable from bestbuy used now it works fine.
tc
Postby Myrmidon » Mon Aug 04, 2008 7:24 am
After checking my wiring, i noticed a slight error with my crystal wiring so i changed it. Hooked it back up, but i'm still getting the same error.
EDIT: Also, after this error if i click on connect again i get this additional error:
File "pySIMserial.pyc", line 143, in openSession
File "serial\serialutil.pyc", line 166, in __init__
File "serial\serialwin32.pyc", line 49, in open
serial.serialutil.SerialException: could not open port COM4: (5, 'CreateFile', 'Access is denied.')
Myrmidon
Re: Reader connection problems
Postby pedrosa » Wed Apr 29, 2009 8:30 pm
i everybody
i have just made my simreader in the array test plate, and it just doesn't come alive.
the computer (xpsp3) doesn't detect it.
any good ideas?
BR
pedrosa
pedrosa
Return to Citizen Engineer (retired forum)
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
