A smaller rand()?
A smaller rand()?
Postby SolidSilver » Sun Aug 31, 2008 11:42 am
I have a little project on the ATtiny13 that needs some random numbers. I got one rand() call in and the code went from ~150 bytes to almost 800. A second call pushed it over the limit. Sure, I could move it to a tiny85, but a) I don't have any, and b) I'm curious about alternatives to the stdlib rand() code. Part of the bloat might be the avr/delay.h stuff, as well. I'm looking into cutting that down.
Meanwhile, does anyone have a smaller solution to get some random?
SolidSilver
Postby mtbf0 » Sun Aug 31, 2008 1:09 pm
if you're not using all of the a/d pins, you could try just reading an unconnected one. or, if you've got a nice noisy analog signal hooked up you sample it a few times and build a random number by shifting in the low order bit(s) of whatever you get.
mtbf0
Postby westfw » Sun Aug 31, 2008 2:57 pm
How random do you need? I used the something like the following to drive some LEDs in a "flicker" brightness that was supposed to look like flames.
* 127 state pseudo-random numer
* Shift register with feedback at bits 0,6
* (The macro is tested, the function is not.)
#define nextrandom(last)  \
    newbit = last & 0b01000000;  /* bit 6 */  \
    if (last & 1)            /* bit 0 */ \
      newbit ^=  0b01000000; \
    last = (last>>1) + newbit;
unsigned char rand(void)
    static unsigned char rand_seed;
    unsigned char newbit;
    nextrandom(rand_seed);
    return(rand_seed);
And here's a 16bit version...
* pseudorandom
* return the next pseudo-random number (PRN) using a standard maximum
* length xor-feedback 16-bit shift register.
* This returns the number from 1 to 65535 in a fixed but apparently
* random sequence.  No one number repeats.
* (This is the "standard" linear shift register with xor feedback PRN;
* other PRN generators could be used.)
static unsigned short pseudorandom16 (void)
    unsigned short newbit = 0;
    if (randreg == 0) {
        randreg = 1;
    if (randreg & 0x8000) newbit = 1;
    if (randreg & 0x4000) newbit ^= 1;
    if (randreg & 0x1000) newbit ^= 1;
    if (randreg & 0x0008) newbit ^= 1;
    randreg = (randreg << 1) + newbit;
    return randreg;
PRNGs make for pretty ugly C code; it's one of those bit-intensive things that CAN work more elegantly in assembler.
westfw
Thanks, westfw!
Postby SolidSilver » Mon Sep 01, 2008 11:58 am
Perfect! Swapping in the 16-bit rand routine cut the object code down to 342 bytes. Interestingly enough, this project is a flickering LED. :lol: Looks like I'll have enough room to get a more realistic dither in the pattern.
Thanks for the tip!
SolidSilver
From concept to Instructable
Postby SolidSilver » Fri Sep 05, 2008 7:23 am
Thanks for the suggestions, everyone. The end result is now an Instructable project.
SolidSilver
Re: A smaller rand()?
Postby SolidSilver » Wed Oct 22, 2008 12:08 pm
Woo hoo! My Instructables project got linked from Hack-a-day! (no, the link is in the story, not the headliner)
SolidSilver
Users browsing this forum: No registered users and 9 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
