Ubuntu Linux Avrdude problems Brain Machine
MiniPOV, MiniPOV2 and MiniPOV3
Postby Louie Plank » Sun Oct 05, 2008 2:15 am
I am having problems getting the minipov programmed using the console. Any ideas? Thanks
Louie Plank
Postby The_Don125 » Sun Oct 05, 2008 2:23 am
What command are you using to program, and what is the error?
The_Don125
Ignorance
Postby Louie Plank » Sun Oct 05, 2008 2:58 am
I am just trying to get it to communicate through the serial port. Trying to teach this old dog new tricks. I am having a tough time finding documentation.
Louie Plank
Postby The_Don125 » Sun Oct 05, 2008 9:02 am
http://www.ladyada.net/make/minipov3/so ... html#linux
Thats probably going to be your biggest help.
Edit the Makefile in the minipov directory to change the AVRDUDE_PORT to /dev/cuaa0, /dev/ttyS0, /dev/ttyUSB0, /dev/cu.KeySerial1 or /dev/cu.usbserial or whatever you're using. (Check your distribution docs for info on what the serial ports are called!)
Since you run Ubuntu, you want to use /dev/ttyS0 if you are plugging the miniPOV into a serial port (/dev/ttyS1 if your computer's COM1 port is already in use, which is unlikely for modern PC's). If you are using a USB-Serial converter cable, use /dev/ttyUSB0.
Also, don't forget to check all solder connections for breaks and bridges, and make sure the MiniPOV's battery pack is on when you try to communicate.
The_Don125
thanks
Postby Louie Plank » Mon Oct 06, 2008 1:17 am
I can see it but now I get errors, do i still do the make-program like in the instructions.
I was delighted to switch to Linux about 5 years ago. But I am 53, trying to keep my mind active....... :shock:
Thanks for the help now I get an error 1
Louie Plank
Re: thanks
Postby mtbf0 » Mon Oct 06, 2008 3:16 am
Louie Plank wrote:I can see it but now I get errors, do i still do the make-program like in the instructions.
yes. what errors are you getting?
mtbf0
Postby The_Don125 » Mon Oct 06, 2008 9:07 am
I believe error 1 says that it can't find the AVR device. Make sure all of your solder connections are good, the chip is installed the correct way, and the battery pack is on when you try to program.
The_Don125
Postby niksun » Mon Oct 06, 2008 3:43 pm
A while back, I posted this. Maybe it can be of *some* help.
Niksun
If you thought before that science was certain--well, that is just an error on your part. -- Richard Feynman
niksun
Return to MiniPOV
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
