Problem programming SLM
MiniPOV, MiniPOV2 and MiniPOV3
Postby ccoshow » Mon Nov 03, 2008 2:18 am
Hi. I bought a Brain Machine at Austin Maker Faire. I've set up my MiniPOV, and it tested out OK. I've followed the tutorials, and downloaded Avrdude, WinAVR, and the MiniPOV3 code, following the instructions in the Brain Machine manual. I've gotten to the following steps, and here is the error message I get:
C:\slm>make mypov.hex
ECHO is off.
Compiling: mypov.c
avr-gcc -c -I. -g -Os -funsigned-char -funsigned-bitfields -f
pack-struct -fshort-enums -Wall -Wstrict-prototypes -DF_CPU=8000000 -Wa,-ad
hlns=mypov.lst -mmcu=attiny2313 -std=gnu99 mypov.c -o mypov.o
process_begin: CreateProcess(NULL, avr-gcc -c -I. -g -Os -funsigned-char -funsig
ned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -DF_CPU=8000
000 -Wa,-adhlns=mypov.lst -mmcu=attiny2313 -std=gnu99 mypov.c -o mypov.o, ...) f
ailed.
make (e=2): The system cannot find the file specified.
make: *** [mypov.o] Error 2
C:\slm>
I'm using Windows XP. Can anyone help me figure out what's wrong? Thanks.
ccoshow
Re: Problem programming SLM
Postby mtbf0 » Mon Nov 03, 2008 3:33 am
does mypov.c exist in C:\slm?
mtbf0
Postby ccoshow » Mon Nov 03, 2008 10:48 am
Yes, it's in there. I just double-checked.
ccoshow
Postby mtbf0 » Mon Nov 03, 2008 11:08 am
try the following from the command line to see what it says...
avr-gcc -c -I. -g -Os -funsigned-char -funsigned-bitfields -f pack-struct -fshort-enums -Wall -Wstrict-prototypes -DF_CPU=8000000 -Wa,-ad hlns=mypov.lst -mmcu=attiny2313 -std=gnu99 mypov.c -o mypov.o
looks like windows maybe isn't finding avr-gcc. does windows have a whereis command? check your path.
mtbf0
Postby ccoshow » Mon Nov 03, 2008 12:20 pm
Where should avr-gcc be? Should it be in the slm folder? What kind of file is it, c, or exe, or what?
ccoshow
Postby ccoshow » Mon Nov 03, 2008 12:27 pm
Hah! Found avr-gcc in my WinAVR\bin folder, so copied ALL files from that folder into my SLM folder. Then went back to the CMD prompt and tried MAKE MYPOV.HEX, and it worked fine. Thanks for your help!
ccoshow
Postby mtbf0 » Mon Nov 03, 2008 1:05 pm
the correct course of action would have been to add C:WinAVR\bin to your PATH environment variable. here's a page that tells how that can be done.
http://www.computerhope.com/issues/ch000549.htm
seems like diddling autoexec.bat was a whole lot easier.
mtbf0
Return to MiniPOV
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
