avrdude/FTDI upload problems...
Moderator: adafruit
Postby Dan_K » Mon Dec 29, 2008 9:08 am
Hello again. I've been using my Fuzebox just fine for the last few days, but today I tried to upload a new version of my Minesweeper game that I've been working on, but avrdude can't seem to talk to my Fuzebox anymore.
Here's the error that I get:
C:\Users\Dan>avrdude -p m644 -c stk500v1 -P COM8
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x42
avrdude: initialization failed, rc=-1
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
I realise this is the same error that has occurred in another thread on this forum, and I've tried the following:
- Unplug/Replug the cable
- Rebooting my computer
- Checking the RTS hack
- Undoing the RTS inversion hack
- Pressing reset just before an upload
I have no idea what could have caused this to happen. The Fuzebox itself will run fine with the last program that I uploaded, I just can't communicate with it anymore for some reason. Maybe it's Vista being problematic, I'm running Vista x64.
Dan_K
Re: avrdude/FTDI upload problems...
Postby adafruit » Mon Dec 29, 2008 11:17 am
does the red LED blink a couple times when you reset it?
Postby Dan_K » Mon Dec 29, 2008 11:44 am
Yes. When I press the reset button on the board the LED blinks 3 times. When I plug the cable into the board (the DC cable is not plugged in, just the FTDI/audio/video/controller cables) the LED blinks 3 times, and also blinks when I try to run avrdude; which makes me think that the bootloader hasn't been overwritten...
Initially, it was on the port COM6, but after plugging in the cable again (from the USB port, not the board) it changed to COM7, and has since changed again to COM8; I don't know if this affects anything.
Dan_K
Postby adafruit » Mon Dec 29, 2008 2:51 pm
whenever the com port changes, it also changes the RTS on-close setting (annoying!) perhaps try setting it again?
Postby Dan_K » Mon Dec 29, 2008 3:11 pm
No such luck unfortunately :( I have tried disabling and then re-enabling the port in the device manager also, but no change came from it.
Dan_K
Postby jleemero » Fri Jan 02, 2009 2:52 am
Same problem I was having, and hey look, he's using Vista. Just like me.
jleemero
Postby adafruit » Sat Jan 03, 2009 4:24 pm
oh argh. do either of you happen to have a scope? i need to install vista on something so i can test it, its very finicky :D
Postby Dan_K » Tue Jan 06, 2009 10:54 am
Unfortunately, I don't have a scope. I'm new to the electronics side of things (coming from programming) so all I have is a multimeter :(
Dan_K
Postby adafruit » Tue Jan 06, 2009 11:08 am
ok, i havent had time to install vista so maybe you can try this:
put a wire between the yellow and orange pins on the FTDI cable
open up hyperterm or whatever, and connect to the comm port (any baud rate)
type stuff, does it get echoed?
Postby jleemero » Tue Jan 06, 2009 7:18 pm
Doesn't work for me.
I use AbsoluteTelnet. (Vista doesn't come with HyperTerm, sadly.)
jleemero
Postby adafruit » Tue Jan 06, 2009 8:47 pm
really??? are you sure the wire is connecting the orange and yellow cables, you dont have any hardware handshaking / flow control, etc?
Postby jleemero » Tue Jan 06, 2009 9:16 pm
ladyada wrote:really??? are you sure the wire is connecting the orange and yellow cables, you dont have any hardware handshaking / flow control, etc?
Orange and Yellow.
NOTHING is happening, at all.
Now, as a note, I only ever use this thing for Telnet, this is the FIRST time I've ever used anything but hyperterm to connect directly to a COM port like this.
I really with Vista had Hyperterm :(
I'm just glad I got my USBTinyISP working, so I can at least still use my Fuzebox until this issue is sorted out.
jleemero
Postby uze6666 » Wed Jan 07, 2009 9:01 pm
So if you can use ISP, why exactly do you still want to use the FTDI/Serial way?
Uze
uze6666
Postby jleemero » Wed Jan 07, 2009 10:39 pm
Uze
Simplicity, only 1 cable. :P
jleemero
Postby adafruit » Thu Jan 08, 2009 12:33 pm
the ftdi cable is a bit faster too, actually.
i'm somewhat suspicious of the FTDI driver, since it doesnt seem like the cable 'works at all' under vista
do you recall which driver you downloaded?
Next
Return to Fuzebox
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
