What are the most commonly used components?
Post test messages here
Postby mkub » Sat Jan 24, 2009 6:56 pm
What are the most commonly used components and why? Like resistors, capacitors, led wise, etc.
mkub
Re: What are the most commonly used components?
I guess you don't have to post why.
mkub
Postby The_Don125 » Sat Jan 24, 2009 8:12 pm
Probably resistors, since many things them to operate. All LEDs need resistors so they don't blow up for example.
The_Don125
Postby mkub » Sat Jan 24, 2009 8:29 pm
Oh I see. So what resistances do you think are most commonly used?
mkub
Postby magician13134 » Sat Jan 24, 2009 9:18 pm
In integrated circuits the most common pieces are transistors. But for regular circuits, I'd have to go with resistors, although lots of my circuits use more LEDs than anything else. For instance, I may have a microcontroller driving 8 LEDs, so there would be 1 microchip, 1 transistor, 1 shared resistor and 8 LEDs.
magician13134
Postby westfw » Sun Jan 25, 2009 12:27 am
220, 1k, 10k, 100k, 1M.
220 is your general LED current limiter for 5V (gives about 15-20mA)
1K for transistor bases and more severe current limiting.
10k for pullups and pulldowns on logic.
100k an 1M are less common but show up in longer timing circuits (Mohms * uF = s)
For modern digital circuits, values are VERY loose. Some people like 10k for pullups, others use 4.7k, and people who remember TTL like 2.2k. I got some good deals once on some 1% SMT resistors that I expect to use for most purposes: 1510 ohm (~1k), 9100 (~10k), 909k (~1M), etc...
If you're going to be doing analog circuitry like x0xb0x, you'd better uses exactly the values specified.
westfw
Postby magician13134 » Tue Jan 27, 2009 4:51 pm
I'd have to add 47 to westfw's list. I use those most often for LEDs powered by microchip output. For something like the MiniPOV where it's only getting a little power from an output pin rather than a direct power source like a battery.
magician13134
Postby minerva » Sun Dec 06, 2009 11:20 pm
So, you want to build up a little stock of common components for experimenting? Something like that?
Here's what I'd recommend.
Plenty of resistors: 100R, 220R, 470R, 1k0, 2k2, 3k3, 4k7, 10k, 22k, and 100k are 10 nice common useful values.
Capacitors: 100 nF (lots!), 10 uF and 100 uF for power supply filtering.
A few 7805 regulators.
Some 1N4004 diodes (or 1N400x, anything similar) and some 1N4148s.
Some common transistors... say, some 2N3904s and 2N3906s, or BC548/BC558s.
minerva
Return to Test Message Forum
Users browsing this forum: Google Feedfetcher and 1 guest
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
