Wattcher Is Awesome, Can someone help me use it another way.
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby paulrich » Wed Jan 28, 2009 6:27 pm
I have a electric r/c car I race indoor wish to use the idea of Wattcher to monitor my voltage.
Can I use the same software and building instruction and programing of the xbee or do I need to tweak something ?
Thanks Very Much, Paul
paulrich
Re: Wattcher Is Awesome, Can someone help me use it another way.
Postby adafruit » Wed Jan 28, 2009 8:50 pm
thats a good idea! yes you can adapt it to work just fine. make sure the voltage range is 0 to 3.3v, in case the RC car is 7v or 12v.
be sure to post if you get it working!
Postby mojo » Sat Jan 31, 2009 2:01 pm
I made a simple device like this for a friend of mine to use on his model helicopter.
I was originally going to just use an op-amp as a voltage comparator with a reference voltage and light up and LED when the battery gets low. That would keep the component count and the weight down. We got a working circuit which was going to be re-done in surface mount parts to keep the weight as low as possible, but in the end decided not to make a PCB and instead look at doing a more complex AVR based system that could transmit telemetry too.
If you are just going to use stripboard or matrix board then an op-amp to scale the voltage connected to the XBee is probably the simplest solution. The Kill-a-Watt is more complex because it deals with AC voltage. Since you have more analogue inputs you could use a dual/quad op-amp and add some extra sensors (e.g. thermistors for motor temperature).
mojo
Return to XBee products from Adafruit
New Products [107]
More Dev Boards[31]
Components & Parts[70]
LEDs[111]
Cables[62]
