by guest » Thu Feb 19, 2009 2:20 pm
if you just want to change the attack
you only use the front portion of the schematic
place one end of a .22uf capacitor
at the juncture of r133 and r131
and the other end to ground
and then put a a diode from that same juncture
to the d34 and d35 juncture
so that the diode conducts
when the gate is turned off
this increases the attack time from .75ms to 2.5ms or so
it also increases the release time from 10ms to 20ms
varying r133 varies the attack time
the release time is set by r145
which cant be made much smaller
its pretty subtle like this
but if you put in the transitor buffer before r131
you can make the attack and decay times much longer or shorter
