Problem ordering board...
Minty so good. Minty so tasty.
Postby Manny » Thu Jan 19, 2006 1:40 pm
I followed the tutorial from http://www.sparkfun.com/tutorial/PCB/eagle-output-tutorial.htm to generate the files to order the PCB, but 4pcb has kicked the order back saying I need to include a board layout. Any easy way to do this, or have I missed a step?
[/url]
Manny
Postby ut20xx » Thu Jan 19, 2006 6:05 pm
What exactly do you mean by a board layout?
In case this helps, I also ordered from 4pcb.com, but the only problem I encountered after follwoing the same tutorial was the lack of a board outline. I fixed this by including the dimension layer on at one of the files on the CAM Processor in Eagle.
ut20xx
Postby Guest » Thu Jan 19, 2006 6:52 pm
Whoops! Should have said board outline. How do I add the dimension layer you mentioned?
Guest
Postby ut20xx » Fri Jan 20, 2006 3:33 pm
When you are on the CAM Processor on Eagle and select Dimension from the list on the right (under Layers). Then click process selection. Tell 4pcb.com that the outline is on the Top Component/Copper Layer (.cmp file)
ut20xx
Postby Manny » Sat Feb 04, 2006 12:39 pm
Just got my board. Thanks for your help.
Manny
Return to MintyMP3
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
