I have some more extras of these:
If you buy a kit, you can get an extra set of these for $10, sorry but it is too much extra work just to send these separate.
10pcs = $10.
In sets of 10 x 2SA733(AP) TO-92 PNP Transistors <- Like the original TB303).
The 3 Critical Transistors will be selected for High Beta (like the original TB303).
These are for use for Q8, Q9 and Q10.
NOTES:
- If you are buying a kit from me, then you don't need these as a 'Rare Parts Kit' comes with 10 PNP Transistors (including the 3 selected) for the critical spots.
- These are listed everywhere, but are usually not usually actual 2SA733(AP)'s, when you go to order them they mysteriously turn into 2SA733(P)'s or they run out of stock.
- These are the real thing and came sealed on original (anti-static) factory packaging with manufacturers labeling etc.
- Do not ask for 3 high gain ones only as I have had to buy all of these to test for the high gain ones, and I will guarantee that the three of them that are critical are high gain (try buying transistors from someone else and see if they guarantee this, you could buy hundred's and not get any).
