Minipov ideas
MiniPOV, MiniPOV2 and MiniPOV3
Minipov ideas
Postby tkerby » Wed Apr 15, 2009 5:24 am
Three ideas (which may have been considered before)
- Why not use the eeprom to store the messages as a string. That way avrdude or similar can write direct to the flash and by loading a text file in binary mode you should be able to directly send your strings. A special character could be used to terminate strings such as a double line return in the file
- With the chemical / uv version, how about using an optical encoder to measure distance travelled along the surface thus controlling font width. A mouse wheel would be ideal for this. I'm also thinking it would then make a viable controller for projects like the bikes that write on the road with chalk or a low cost tshirt printer (pens attached to solenoids and dragging the tshirt past the wheel
- Would it work to have three colums of leds in red, green and blue and set a single pixel delay between them to colour mix and create a multicolour version?
tkerby
Re: Minipov ideas
Postby mtbf0 » Wed Apr 15, 2009 10:14 am
tkerby wrote:Three ideas (which may have been considered before)
there's a lot more flash than there is eeprom, so the chemical pov uses flash. after all, you've got to fire up avrdude, anyway.
i've been thinking about this apropos an old testament magic eight ball project i have in mind.
or one column of rgb leds. color mixing requires a lot more computational oomph, higher interrupt rates to vary intensities, but sure.
mtbf0
Re: Minipov ideas
Postby lmwangi » Sat Oct 10, 2009 12:39 pm
How about adding a way to stream text to the pov?
<Disclaimer: Now I go wild> Maybe coupling it with http://www.tuxgraphics.org/electronics/ ... 6111.shtml to have simple tcpip functionality to read a special daemon that streams text from rss say from slashdot? That'd be cool... If we need to wave it around, we can have a motor do that <end wild mode>
lmwangi
Re: Minipov ideas
Postby mtbf0 » Sat Oct 10, 2009 9:42 pm
the attiny2313 on the minipov3 has a uart and the pins it uses are not being used for anything else. should be easy to connect to an ftdi usb-ttl serial cable that is used to program the dc boarduino.
mtbf0
Return to MiniPOV
Users browsing this forum: mibignistinly and 1 guest
New Products [102]
LEDs[109]
Cables[60]
