Widget issues..
Talk about YBoxen, widgets, Propeller hacking, etc!
Widget issues..
Postby Abysmal » Sun Apr 26, 2009 7:22 pm
I started trying to play with some spin code and tried to run some compiled binaries on my YBOX2 as a widget..
I made sure the pin outs for video were correct.. I compiled some simple code from the obex files from parallax and did the standard upload using curl and it all went good until i hit the button to run the second stage boot with the new code.. and the the unit just locks up.. the led goes off and the button doesn't do anything and well to get it to do anything I have to pull the power..
What am I doing wrong?
Abysmal
Re: Widget issues..
Postby Abysmal » Mon Apr 27, 2009 9:40 pm
Well after wiring up a tv out port on my parallax protoboard and getting the same failure.. I changed my setup.. apparently the video in on my pvr hooked up to my TV doesn't like this video signal at this frequency/resolution .. but my TV does.. all fixed..
Abysmal
Re: Widget issues..
Postby darco » Mon Apr 27, 2009 10:27 pm
Wait... this sounds kinda fishy. Is your program doing something weird? You can see the bootloader just fine, but the program you wrote doesn't display properly?
darco
Re: Widget issues..
Postby Abysmal » Tue Apr 28, 2009 12:36 pm
I thought weird too, but after years of IT i changed the config.. when i abandoned testing on the YBOX2, i move to the protoboard, but before I did that I wrote the old tell tale LED flasher and uploaed it to the ybox and it worked perfect.. so it had to be the video.. and when it failed on the protoboard, i figured it was time to change the monitor, so I went directly to the tv instead of through my pvr, which was working for the 20x13 text mode.. and once i switched to direct it worked.. and then I tried it on the protoboard with the TV and the 3 inch display.. all working fantastic..
Abysmal
Return to YBox2
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
