alternative parts
Re: alternative parts
Postby magnus » Wed Nov 12, 2008 11:42 am
Does anyone know if 74HC595N can be replaced by 75HC595? One of my ICs heats up like crazy and my x0xb0x won't produce sounds. I can't find a 74HC595 for a reasonable price in England, but the guy at Maplin told me to order a 75HC595, which they sell very cheap. Any thoughts? Cheers
magnus
Postby mome rath » Wed Nov 12, 2008 12:08 pm
magnus wrote:Hi,
I have a few in the US that I could send if you PM me your info
mome rath
Postby zeropoint » Mon Feb 02, 2009 8:21 am
I have a question about the USB interface chip in the official parts list. According to Mouser the FT232BM is obsolete. They suggest the FT232BL as a "similar product." Has anyone verified that it will work as a drop-in replacement?
zeropoint
Postby niksun » Mon Feb 02, 2009 9:08 am
The replacement is fine. Take a look at this post.
Niksun
If you thought before that science was certain--well, that is just an error on your part. -- Richard Feynman
niksun
Postby x0xBuilder » Wed Mar 25, 2009 7:24 pm
Hi everybody,
About usb chip do you think that's possible to replace Ft232BL by TUSB3410IVF or TUSB3410VF ?? it's coming from Texas Instruments !!
Thanks.
x0xBuilder
Postby adafruit » Sun Apr 12, 2009 1:01 pm
even tho the FT232BM has been improved upon with the FT232RL its still available and the I/O board is designed for it
Postby toxaco » Sun May 31, 2009 4:38 pm
Sanyo JC546 as a replacement for 2sc536-f ? ? ?
http://www.datasheetcatalog.com/datasheets_pdf/J/C/5/4/JC546.shtml
it's got the right pin out, anyone got any ideas on this one ?
came up as a replacement when i was doing a search
2sc536 datasheet: http://www.datasheetcatalog.com/datasheets_pdf/2/S/C/5/2SC536N.shtml
don't know enough to compare them
toxaco
Postby Gaetano » Sun May 31, 2009 6:56 pm
They should be similar, the 536N is a higher rated voltage, than the original 536F, from memory:
VCBO VCEO
536F 40v 30v <- from memory
536N 60v 50v <- from your datasheet
Try them out, they won't do any damage, they may just sound different, they have the same pinout, so they'll drop straight in :)
To make your own x0xb0x the 'Rare' parts are here: viewtopic.php?f=29&t=5526
(BA6110, AN6562, 2SC2291, 2SC1583, 2SK30AO, 2SK30AY, LA4140, 2SC945P or 2SC536F, 2SA733AP)
All the other parts are easy to get.
Gaetano :)
Gaetano
Postby tony909 » Sun Nov 15, 2009 9:31 pm
Does a LM78M05CT work instead of a MC78M05CT ? from mouser?
Theres a 0.5amp less difference.
cheers
tony909
Postby tony909 » Tue Mar 23, 2010 7:26 pm
Can transistors 2SC536F be replaced with 2SC536 ? Not sure whether the (F)suffix matters?
Cheers :)
tony909
Re: 4-Turn trimmer substitute for VCO tune & width adjustmen
Postby textile » Thu Apr 15, 2010 8:00 pm
bcbox wrote:I'm using some very nice 4-turn trimmers for my x0xi0 mod for VCO Tune and Width adjustements. I'm using them because it has two VCO's and it's more critical to have fine adjustments but I have also found it can be hard to get an exact setting with the single turn trimmers in the stock x0xb0x (or TB-303 for that matter). The part is also a standard drop-in replacement. They're not cheap but well worth it....
Digikey Part #'s
3339P-503LF-ND
3339P-502LF-ND
Mouser Part #'s
652-3339P-1-503LF
652-3339P-1-502LF
(they're significantly cheaper at Digikey)
They are not half expensive :shock:
These 12 turn fit and are a LOT cheaper
Mouser Part#
81-PV37W502C01B00 for the 5k
81-PV37W202C01B00 for the 2k
81-PV37W503C01B00 for the 500k
I included the trim for the 5.333v because its just as important.
Its just not worth using the single turns.
textile
Postby textile » Wed Apr 28, 2010 7:53 pm
update;
These 12 turn trims are really small and they fit perfectly .
The larger type also fit but these fit better.
textile
Postby mazatta » Wed Apr 28, 2010 11:33 pm
The Alps RK09D1130A0S (available at Mouser) has been suggested previously as a replacement for the Panasonic EVU-F2LFL3B54 (aka P3K1503-ND @ Digikey)
Any idea if an Alps RK12L12C0A0H will replace the Panasonic EVU-F2LFL3B54? I just ordered some to try out but thought I'd ask in case anyone has tried already.
mazatta
Postby textile » Tue May 04, 2010 9:06 pm
Well they both are linear and the right size , there might be something I can't see. Mouser are out of stock at the moment, but it looks like a better option due to the fact that the trimming of the shaft won't be needed and that most of the order (for me) comes from mouser.
textile
PreviousNext
Return to Making x0x
New Products [103]
LEDs[109]
Cables[61]
