Problem with arduino (does not upload any more)
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
Postby Rob K » Wed Jun 10, 2009 6:52 pm
I have only had it out of the box for less than 30 minutes and started having a problem. The problem is that when if fist went to upload a sketch it worked doing just the basic blink sketch. That worked fine on my computer. When I tried it on another computer with the same sketch it did not write a sketch it just took a while till it finally said.
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Power LED is lit and RX and TX blink for a few seconds when I plug it in, and the onboard LED for 13 blinks very dim a few times.
It also says and does this now on the first computer I used even with renaming com ports and restarting computer.
Duemilanove w/328
OS Vista 32
latest FTDI driver
Arduino 0016
“Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns”
-Mitch Ratcliffe
Rob K
Re: Problem with arduino (does not upload any more)
Postby adafruit » Wed Jun 10, 2009 11:41 pm
make sure you have the right board & serial port selected. then check again!
when you move computers it will change
Postby Rob K » Fri Jun 12, 2009 12:35 pm
COM2 USB Serial Port
COM2 selected in Arduino IDE
Some times uploading the blink sketch RX blinks TX does not blink and L lights up and stays on till I hit reset button on board or unplug the USB.
Still giving the same error.
Could this just be a bootloader issue?
-Mitch Ratcliffe
Rob K
Postby adafruit » Sat Jun 13, 2009 2:02 pm
make sure you have the right board selected
Postby Rob K » Sat Jun 13, 2009 4:24 pm
For some reason now it is working and i did not change anything.
-Mitch Ratcliffe
Rob K
Postby Rob K » Mon Jul 06, 2009 11:26 pm
It's still acting odd. Works one day then gives the same error as before.
-Mitch Ratcliffe
Rob K
Postby adafruit » Tue Jul 07, 2009 1:34 am
google around to see if its vista misbehaving with the arduino drivers?
Postby Rob K » Thu Jul 16, 2009 8:24 pm
It is the same with every computer that I have tried it on. Just works when it wants to.
-Mitch Ratcliffe
Rob K
Postby adafruit » Thu Jul 16, 2009 9:48 pm
do you have things/shields connected to it while its happening?
Postby Rob K » Wed Aug 19, 2009 2:18 pm
I have used it with the protoshield and without, but get same results.
Still works when it wants to but now nothing but the same as before for the last month. RX and TX blink for a few seconds when I plug it in, and the onboard LED for 13 blinks very dim a few times. When up loading only RX blinks a few times then I get the error after a min or so.
Ill see if the electronics department at my college has a avr programmer an redo the botloader.
-Mitch Ratcliffe
Rob K
Postby Rob K » Fri Dec 25, 2009 11:48 pm
Sorry for complaining about this to much.
It ended up being that the original oscillator had stopped working, and by soldering in a new one. The Arduino now work perfectly, but a little dusty. Now that I finally have some free time over the holidays I can start working on projects.
-Mitch Ratcliffe
Rob K
Postby Hutch07 » Wed Dec 26, 2012 6:21 pm
I have the same issue. This has an upload brain of it's own. It seems to work when it wants with no methodology. Does anyone know a sure way to upload? How can I tell if the oscillator is bad? It has been doing this from day one.
Hutch07
Return to Arduino Starter Pack
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
