pitch of the ft232 chip?
x0x0x0x0x0x
Postby Brandon Daniel » Fri Mar 11, 2005 11:48 pm
I can handle thru-hole stuff OK, but the surface mount part has me a bit worried. I can rope in the gf for that if it's not too fine a pitch, does anyone know what it is?
Brandon Daniel
Postby Exogenous » Sat Mar 12, 2005 10:43 am
I believe the chip has a 0.8 mm pitch (32LD LQFP format). See http://www.ladyada.net/make/x0xb0x/fab/ ... index.html for some hints on soldering, and similarly the "soldering considerations" at the bottom of this page: http://www.mellowparenting.demon.co.uk/ ... sbdac.html
I'm a bit intimidated myself by the prospect of working on the small surface mount stuff.
Exogenous
Postby adafruit » Sat Mar 12, 2005 3:16 pm
well it is a fine pitch...but its also one of the last things you'll solder. assuming you have the proper tools, you'll find that by the time you get to it, it'll be a lot easier than it seems now.
also, you dont -have- to solder that chip in. its for USB and USB is not necessary for the synth to work!
Postby Brandon Daniel » Tue Mar 15, 2005 4:25 pm
ladyada wrote:well it is a fine pitch...but its also one of the last things you'll solder. assuming you have the proper tools, you'll find that by the time you get to it, it'll be a lot easier than it seems now.
Thanks for the info, if I send the GF to work to do it, she should be able to handle that pitch with the tools there.
Brandon Daniel
Return to General x0xing
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
