SokkOS, new modified firmware
Re: SokkOS, new modified firmware
Postby Sokkan » Thu Apr 23, 2009 3:59 pm
julienvoirin wrote:EDIT : after playing longer : ULTRA BUG : x0x is not ultra responsive to Start msg, often it isn't recognized.
OOPS!
Skit också...
I actually never tried 1.9 slaved to MIDI, it did really suck, like, not work at all(or close to). Sorry about that! :oops:
I have rewritten it and fixed it now(and I dug out my MIDI merger and actually tested to change pattern while slaved to different MIDI clock).
(The banned I did on sunday was actually quite bad...)
So, current release is 1.9.1.
How to use it?
MIDI pattern change behaves as if you pushed a pattern select button or twisted the bank knob, that is, it will change pattern the next time it starts over again. If you want to program pattern changes into your DAW, you only need to make sure the pattern change message appears within the pattern playing just before you want it to switch. You will get visual feedback if you change the pattern number. It also works when it isn't running so you can send it a pattern change message before the song starts too. :)
Note, it will not send pattern change messages, I saw no point in that, but that could easily be implemented if someone might need it.
Sokkan
Postby julienvoirin » Thu Apr 23, 2009 8:08 pm
in fact it seems that MPC sends continue message, when we expect Stop msg. Scanning with midi monitor tomorrow to be sure ..
julienvoirin
Postby resonator » Sat Apr 25, 2009 11:11 am
Are you guys using the JJ OS or the AKAI OS for the MPC2500?
http://www7a.biglobe.ne.jp/~mpc1000/mpc2500/
resonator
Postby phono » Sat Apr 25, 2009 1:31 pm
resonator wrote:Are you guys using the JJ OS or the AKAI OS for the MPC2500?
not until they make me a version for 2000xl or 500 :lol:
/me hides
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Postby ozx0xb0xer » Thu Apr 30, 2009 8:59 am
SokkOS 1.9 uploaded via c0ntr0l on an Intel Mac with 10.5.6
Works perfectly. Haven't tested midi sync.
I had a bit of trouble with the serial connection continually dropping out, however turning off/on the x0x while c0ntr0l was running and connected fixed it! (it probably says to do that in the instructions) :wink:
Thanks Sokkan for all your work, it's brilliant.
ozx0xb0xer
Postby lazlokovacs » Mon May 04, 2009 5:19 am
I have some requests / wishes... I think it would be nice to be able to use the UP/DOWN buttons inte play mode, just like the RAS buttons, so you can shift notes up/down an octave. I would also like to be able to retrigger the current note. Sometimes when you tap the accent button in play mode it'll retrigger, so I find myself hammering on the accent button nowadays just to get the note to retrigger. It only works some times though and is not ideal. I would also like to trigger the notes everytime I press a button in keyboard mode and not slide between notes as it will do if I have another button pressed.
I would also rather double the tempo when I press done+tempo, instead of half the tempo.
lazlokovacs
Postby spdk » Tue May 19, 2009 6:58 am
Sokkan wrote:Wow, stop flooding the thread with all your happyhappyjoyjoy praises over MIDI pattern change... :)
Has anyone tested it? I only have a Roland D-50 that is actually a MIDI synth besides the x0xb0xes and it can only send patch change one through 64, I would like to get confirmation that it works all the way up to 128.
It would also be great to confirm that c0ntr0l still works(it does for me) and that the half-time bug is a goner. :D
Yeaahaw!! Let's flood!!!!
Sorry for my late reaction, I thought it would last a while before pattern change would be implemented if implemented at all. But this is great news!
I'm gonna load up the new OS tonight and post my findings. Thanks again!!!
:D
But erm how does it work? Do you have to send program changes to the x0xb0x? I don't know if there's a manual attached to the firmware zip?
spdk
Postby phono » Sat Jun 13, 2009 4:06 pm
finally got around to trying the current build, half tempo works like a charm now, awesomeness!
phono
Postby marcovitch » Sat Jun 13, 2009 10:19 pm
I tested midi sync with my computer on logic pro 8 and it seems ok ... maybe not perfectly syncronized but it could come from my software ... ???
Need to test simply with a drum machine or MPC sampler and see if it does the same ...
marcovitch
Postby phono » Sun Jun 14, 2009 2:53 am
marcovitch wrote:I tested midi sync with my computer on logic pro 8 and it seems ok ... maybe not perfectly syncronized but it could come from my software ... ???
sync works fine here
phono
Postby marcovitch » Sun Jun 14, 2009 11:13 pm
Hey ! I'm back from sync testing :!: :!: :!:
The b0x was really "out of sync" when I tested with a MPC1000 and with a TR626 ???
I reloaded the OS and the sync worked fine after that but it didn't seem very stable to me.
Switching from a patern to an other felt like it was loosing a bit of sync precision.
marcovitch
Postby marcovitch » Sun Jun 14, 2009 11:36 pm
Just a thought for SokkOS 2.0 ... :wink:
Is there a way you could add the original 303's TIME-MODE function ?
I know that we can "kind of" do the same but the 303's TIME-MODE can really make the pattern rhythm "random".
marcovitch
Postby glitched » Thu Jun 18, 2009 11:17 am
Hey there. I haven't been paying attention to the x0x developments recently, but I will continue to post updates on http://x.glitched.org when new software arrives.
I'll put the latest version up there today.
___________________________________
http://x.glitched.org --> x0x firmware repository
#follow me on twitter: d01
glitched
Postby 3phase » Sat Jun 27, 2009 2:10 pm
geat os.. i truly love to be able to go into edit mode without stopping the machine.. and sync is as good/bad as in the normal os..
normal os has a offset of 800 samples..sokkos 860..
#what is probably because of the swing funktion...
2 wishes for future version...
the evilxox os has stronger swing factors.. the last one allready halfs the the speed .. ifound this 2 last extreme swingfactors pleasing..but not enough to go for the evilxox os..
But would be nice to add 2 more swing factors...
The temporary function on rest and accent is nice..but on slide i would preffer to have it switched because its nice to use it as a fade out for the machine and i ve the gate/env on mod that gives with permanent slides a nice variation what is only usable when i dont have to press it all the time.
thanks for the great work
sven
3phase
Postby RodmanSan » Thu Jul 16, 2009 2:58 am
I finally did it.... :lol:
I am using a (old) Mac G4 MP with OS 10.4.11...and downloaded the following progs (tx for the hints Toxaco) :
Python 2.5.4 (Standard install.)
wxpython (Standard install.)
pyserial (Extract files from the archive, open a shell/console in that directory and type: "python setup.py install")
USB Serial Driver : FT232B 2.1.10 (Standard install.)
c0ntr0l for Mac (Just unzip)
After installing everything just be sure to restart the Mac once, then doubleclick c0ntr0l.py and follow the standard procedure to update the firmware of the x0xb0x.
RodmanSan
PreviousNext
Return to x0xm0dz
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
