Hi, I've run into a wall with this problem, and would appreciate any guidance.
I built from parts ordered from Mouser. I'm using a pin swapped FTDI cable to do the programming. I can compile and load the bootloader just fine, but when it starts up I hit this "Initial Configuration Failed!" error. I've connected pins 2 and 7 of the EEPROM, tried swapped EEPROM chips, but no luck.
Am I missing something here? Other suggestions? Would hardware problems be causing this? I didn't attach a buzzer or LED and their associated resistors. Also using a Ethernet jack w/o LED's, so no resistors there either.
I'm getting no activity lights from my router, or connection when connected directly to my computer.
Thanks,
John
