Hi guys,
I'm thinking of a small project to take the existing TV-B-Gone kit and remove as many parts as possible to get it down to the size of an LED throwie. (using a single wide angle, 160degrees maybe)
I'm not particularly experienced with practical circuits so I was hoping if I listed my ideas someone might be able to say 'that'll never work' to some of them.
The ATTiny85V is able to provide 10mA per IO pin (and sink 40mA) according to the datasheet (page 166, unless I've misread it, which is very likely). According to some of the register controls its possible to bring two pins high on the same clock cycle, could one IR led be powered solely from these pins? Either by providing 20mA or sinking 80mA? This would remove the need for the resistor and the NPN.
How much current do the LEDs suck anyway?
We'll use software control instead of a physical switch, so that's another part saving/IO pin to use.
No need for the programming header as its a one-shot device.
Which leaves the AC shunts and the oscillator...
I bought some CR2032 3V cells, ideally I'd like to power the thing from a single cell but I don't know if these little cells can support the drain -- can anyone comment?
Are the shunts absolutely needed? With a single LED the drain will be much less than the 4 LED model and from what I understand about batteries the shunts get more important as the battery ages, but longevity isn't really a concern with this.
Lastly, can I do away with the external ceramic and use the inbuilt oscillator? What sort of problems would this lead to?
Thanks in advance for any support,
Hugh
