Enclosure for the x0xb0x and x0xi0
Re: Enclosure for the x0xb0x and x0xi0
Postby j00lz » Wed Jul 29, 2009 6:32 pm
Please accept my apologies if my previous comments offended anyone. They weren't meant to be taken too seriously... :?
I look forward to seeing many more pictures of whatever makes you happy in the near future.
:lol:
j00lz
Postby RodmanSan » Wed Jul 29, 2009 8:37 pm
Great job on the beautifull x0xb0x case AND the bikes Maxtim...keep those posts coming.... 8)
RodmanSan
Postby j00lz » Wed Jul 29, 2009 8:55 pm
Please accept my apologies if I offended anyone. It wasn't my intention.
My post wasn't meant to be taken too seriously... In retrospect it probably wasn't in the best of tastes. Again sorry.
I look forward to seeing many more pictures of whatever makes you happy. :lol:
j00lz
Postby Luap » Thu Jul 30, 2009 8:55 am
No worries Maxtim, its all good :)
So what are you waiting on for the x0xb0x now?
Luap
Postby dnigrin » Mon Aug 03, 2009 6:57 am
I actually thought there was quite a nice parallel between maxtim's work on his x0xi0 and that on his bikes: precision, attention to detail, high degree of craftsmanship, planning, etc... The skills necessary are the same to do a good job!
dnigrin
Postby phono » Mon Aug 03, 2009 7:08 am
dnigrin wrote:I actually thought there was quite a nice parallel between maxtim's work on his x0xi0 and that on his bikes: precision, attention to detail, high degree of craftsmanship, planning, etc... The skills necessary are the same to do a good job!
hey is that you Dan? :P fancy seeing you here :D
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Postby dnigrin » Mon Aug 03, 2009 7:34 am
Yup, it's me, hi phono! Full .sig below....
Dan Nigrin
Defective Records / MC-202 Hack / Jack OS X / Major Malfunction / PC-1600 User / VSTi Host
http://www.defectiverecords.com
http://www.jackosx.com
dnigrin
Postby mome rath » Sun Dec 13, 2009 8:28 pm
definitely putting this troublesome x0x into the same hammond case (well, the cheaper one without the walnut sides)... i couldn't close it up once I finished the mods :(
this is a good step-by-step, thanks
mome rath
Postby maxtim » Fri Feb 11, 2011 4:20 pm
So, my last post was in July of 2009, when I was forced to shelve the project due to other interests and projects.
Now I am very excited to have some time to continue with this build!
I see that bcbox has a fantastic website set up for the x0xi0 now. In looking through the wealth of new info, pictures and sound clips my enthusiasm is peeking. The Full Installation Manual is now at R2.0, so I have to perform all of the necessary upgrades since I built from V1.0. I have sent an email to bcbox to verify the necessary upgrade path from Rev 1.0 to Rev 2.0.
I have re-painted the Hammond case metalwork with a few new coats of flat black paint after sanding out the couple of dings I had put into it while fitting the PCAs in my original fabrication.
I have wired all of the rear controls for remote mounting on the top of my custom enclosur:
I have started to wire the PCAs together. This is the current state of the PCAs on my workbench:
Next I will have to wait to order the new remote mixer PCA from bcbox and get the other changes implemented that are necessary to reflect the V2.0 x0xi0 design.
While waiting for V2.0 parts I think I will continue with the paint work on my custom enclosure.
Cheers :)
maxtim
Postby isak » Sat Feb 12, 2011 12:07 pm
Hi maxtim
long time indeed :)
great to hear that your back on the project.
waiting to see the end..
as always.. i'm watching your post.
cheers,
Isak E.
isak
Postby maxtim » Sun Feb 13, 2011 10:01 pm
Hi Isak,
Thanks for the ups.....
I have just finished masking the case top.
A simple design of one white stripe across the top of the front and 2 white stripes across the bottom of the top panel (to mimic the simple design of the x0xi0 faceplate).
Then one stripe across the top of the case back and a thinner stripe across the bottom of the back panel.
All the stripes are then boxed in at the ends, terminating before the side of the panels (just like the design of the x0xi0 faceplate)
Now, out to do a little painting :)
Valentines Day tomorrow ;)
maxtim
Postby maxtim » Mon Feb 14, 2011 12:43 am
I finished the painting and mask removal.
Some touch-up on the right corners, but I like the overall result.
Since I had so much white paint left, I painted the inside of the box, which was previously very rough. It will be a great background to all of the colourful wires, and electronics
The back didn't turn out so well because I painted the inside without proper forethought. Some of the masking tape was not properly seated and the white paint bled through to the outside of the case. Every little sliver of white paint shows up oh-so-very-well against the flat black.
Off to do a little touch-up :)
maxtim
Postby maxtim » Tue Feb 15, 2011 10:07 pm
Touch-up...HA! :oops:
I sanded the entire outside of the case, masked the entire inside which is now nice white.
Then I re-sprayed the entire thing. :shock:
This time FOR-SURE :roll:
maxtim
Postby maxtim » Sat Feb 19, 2011 6:03 pm
Woo-Hooo :D
This time, with the practice and practical knowledge that I had gained from the first attempt, it worked exactly as I had envisioned!
I painted the lines on the pots and switches on the x0xi0 too.
maxtim
Postby maxtim » Sun Feb 20, 2011 7:37 pm
So, now that the case painting is complete.
Back to the elecronics:
For the V1.0 to V2.0 upgrade, there were a bunch of components to remove or replace.
I have now completed all of the removals, but await the arrival of the upgrade kit from bcbox to continue further.
maxtim
PreviousNext
Return to x0xm0dz
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
