Programming Bootloader
Moderator: adafruit
Postby Synclavier » Mon Oct 19, 2009 9:39 am
I programmed the Uzebox SD Loader and it doesn't work, and as a result I cannot get the original bootloader back. Programming Boulderdash works...
I used the latest AVR Studio with USBTinyISP, and jumpered R4 and R7.
Does anyone have the correct settings to flash back the original and the Uzebox SD Loader :?:
Synclavier
Re: Programming Bootloader
Postby adafruit » Mon Oct 19, 2009 10:33 am
the bootloader should be in the download package from ladyada.net
Postby Synclavier » Tue Oct 20, 2009 1:07 pm
I have the two bootloaders in hex, but using avrdude I cannot flash them. It gives an error when I program them. I was wondering what special option I need to add to flash the bootloaders (SD and Normal)?
In the meantime I can compiled maze and using avrdude uploading was easy and working. Using avrstudio when I program the bootloaders I get the error 0x013A = 0xFF should be 0x00.
Synclavier
Postby adafruit » Tue Oct 20, 2009 2:12 pm
if you dont need the bootloader, id skip it. it wont be included in future fuzeboxen
Postby Synclavier » Wed Oct 21, 2009 5:07 pm
The Fuzebox is when build a closed box, to program it I have to open it and put a cable inside. If we can use the boot sd loader, we only have to put the files on the sd card.
How do you program the original fuzebox bootloader?
Synclavier
Postby uze6666 » Mon Oct 26, 2009 12:35 pm
When you say it does not work, what's the symptoms? Have you set the bootloader size fuse (BOOTSZ)? The SD bootloader is bigger than the Fuzebox one, so this must be set correctly.
-Uze
uze6666
Postby Synclavier » Wed Oct 28, 2009 3:58 pm
See below the settings:
Synclavier
Postby Synclavier » Wed Oct 28, 2009 3:59 pm
See below the flash
Synclavier
Postby Synclavier » Wed Oct 28, 2009 4:08 pm
When I start the Fuzebox there is a fuzzy line after a few seconds when flashed with avrstudio as a above two pcitures.
Flashing the demo file OK:
avrdude -c usbtiny -p atmega644 -U flash:w:Uzeamp.hex
Flashing the fuzebox bootfile:
avrdude -p m644 -c usbtiny -e -U hfuse:w:0x12:m -U lfuse:w:0xef:m -U flash:w:ATmegaBOOT_644.hex:i
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9609
avrdude: erasing chip
avrdude: reading input file "0x12"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0x12:
avrdude: load data hfuse data from input file 0x12:
avrdude: input file 0x12 contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xef"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xef:
avrdude: load data lfuse data from input file 0xef:
avrdude: input file 0xef contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "ATmegaBOOT_644.hex"
avrdude: writing flash (65512 bytes):
Writing | | 0% 0.00s
avrdude: error: usbtiny_send: usb_control_msg: sending control message failed, w
in error: The I/O operation has been aborted because of either a thread exit or
an application request.
(expected 128, got -116)
Writing | ################################################## | 100% 0.55s
avrdude: failed to write flash memory, rc=-1
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Synclavier
Postby uze6666 » Fri Oct 30, 2009 1:10 pm
I don't know about the Fuze bootloader and I don't use USBTiny, but the settings in the pictures looks good to me, it should work. Which HEX version did you use?
-Uze
uze6666
Postby adafruit » Fri Oct 30, 2009 4:12 pm
try using -B 1 in avrdude
Postby Synclavier » Fri Oct 30, 2009 4:16 pm
In the example in AvrStudio I used the first sdbootloader from the uzebox forum. In Avrdude I used the Fuzebox bootloader, the parameters I used from another standard bootloader with same bootloader size. I checked all available versions of the bootloaders in both programs with different parameters.
One of the issues is that with Avrdude programming the flash is always without problems, using Avrstudio sometimes gives errors (small glitches in the programs, or error during verify).
Synclavier
Postby Synclavier » Thu Nov 05, 2009 4:32 pm
Today received the STK500 avr programmer, and flashed the Fuzebox without any problems. The USBtinyISP did not program the fuses correct.
I compiled the last SDBootloader and works without any problems.... :)
Synclavier
Return to Fuzebox
New Products [107]
More Dev Boards[31]
Components & Parts[70]
LEDs[111]
Cables[62]
