HELP! MiniPOV3 not working
MiniPOV, MiniPOV2 and MiniPOV3
Postby tardis fan » Sun Nov 08, 2009 2:27 pm
I got the minipov from a kit, but I am going to make it into a brain machine. I have a mac os x and using an adapter cable. The lights light up when I turn it on but when I plug it in and type in "avrdude -p t2313 -c dasa -P /dev/cu.PL2303-0000101D" it just says
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
this check.
avrdude done. Thank you.
What do I do?
I am a beginner in programming.
tardis fan
Re: HELP! MiniPOV3 not working
Postby adafruit » Sun Nov 08, 2009 2:35 pm
did you use the updated PL2302 driver we suggest?
Postby tardis fan » Sun Nov 08, 2009 6:03 pm
Yea, I did.
tardis fan
Postby tardis fan » Sun Nov 08, 2009 6:13 pm
I also set the delay to 5000.
tardis fan
Postby adafruit » Sun Nov 08, 2009 7:33 pm
is it on? do you see any blinkin' lights?
Postby FehnrirX » Mon Nov 09, 2009 5:11 am
Sorry, but i have the same trouble here. I make my MiniPOV by myself, not from kit. I use AtTiny2313 and serial port, not usb. Once i plug the serial cable, the second LED is turn on, but when i turn on the battery pack (2), it's off. When i enter the command, it's said "AVR device not responding"
What should i do?
FehnrirX
Postby tardis fan » Mon Nov 09, 2009 9:45 am
Yes, when I turn the device on, it lights up.
tardis fan
Postby adafruit » Mon Nov 09, 2009 11:44 am
make sure the minipov is powered when you try to program it - turn on the battery pack.
next, when you try to program it, some LEDs should blink...do they?
Postby tardis fan » Mon Nov 09, 2009 4:27 pm
When I type in "avrdude -p t2313 -c dasa -P /dev/cu.PL2303-0000101D" and hit enter, the lights keep flashing as they always have.
tardis fan
Postby adafruit » Mon Nov 09, 2009 5:12 pm
hmm, if you plug it in but dont try to program, do ALL the LEDs blink? if not, how many?
if you try to program it, how many LEDs blink?
Postby tardis fan » Mon Nov 09, 2009 5:38 pm
When I plug it in but not program, the four leds that I stuffed light up. Same for when I try to program it.
tardis fan
Postby tardis fan » Mon Nov 09, 2009 5:39 pm
I have only soldered four leds.
tardis fan
Postby mtbf0 » Mon Nov 09, 2009 7:23 pm
sounds like its not going into reset. check the soldering on d3, r11 and pin 7 on the serial connector. might as well check all the soldering, but concentrate on the three diodes, r10-12, and the serial connector. got any nice, in focus, pictures of the board?
mtbf0
Postby tardis fan » Mon Nov 09, 2009 8:22 pm
Yeah, R 12 looks funky. I'll check that
tardis fan
Postby tardis fan » Mon Nov 09, 2009 8:36 pm
Well, I re soldered that and it worked! But... now when I type in "make program-alt_leds" it says
make: *** No rule to make target `program-alt_leds'. Stop.
Now what?
tardis fan
Next
Return to MiniPOV
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
