jvdb wrote:bartgrefte wrote:Can you do that with every clock-kit? (Like the Ice Tube?)
You would first have to figure out where to connect the GPS receiver. The Tubehobby clocks only use 3 pins on the Mini-DIN connector.
Then you would have to write the firmware to support it. You could probably steal most of the code from another project like this:
http://www.dutchtronix.com/ScopeClock.htm
Okay.
adafruit wrote:we'll have a how-to on gpsifying the tube clock shortly. unfortunately we're out of gps modules
Would it be the same as the nixie clocks or different?
