i think its gate mod
Discuss mods, hacks, tweaks, etc.
Postby isak » Sun Jul 26, 2009 4:19 pm
Hi every one :)
question :
if i want to play a sequence with long notes not the short ones like it is now.. how can i do that? is this what u call Gate?
is there any mod to this gate?
thanks from advance
Isak :)
isak
Re: i think its gate mod
Postby phono » Sun Jul 26, 2009 4:57 pm
just place several notes of the same next to each otehr and use slide to tie them to a single note
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Postby isak » Sun Jul 26, 2009 6:36 pm
thanks for u'r reply phono
but i dont want to do it like u said ..its not practical at all.
if there will be long notes and i turn the env mod up to 75% i will get some fatness from the x0x and that what i'm lookong for.
so if any one here knows how to make the gate long notet i'll b happy to know..please :mrgreen:
thanks again phono my man :)
isak
Postby mome rath » Sun Jul 26, 2009 9:54 pm
this works very well
x0xd0x wrote:"Gate On Forever
Tie a line from the juncture of D35 and R133 to a single pole switch, and the other end to 12V. When the switch is on, the gate will be on forever, but the sound will still die when the main envelope closes the VCA. A good place to get 12V is pin 3 of J4 (pin 1 is 5.333v, pin 2 GND and pin 3 12v)"
and it works even better when you tie it to this:
x0xd0x wrote:"VCA Envelope On Forever
Tie a line from the juncture of D36 and R134 to a single pole switch, and the other end to 12V. In conjunction with the Gate On Forever mod (see above), this will allow the sound to play forever."
I generally put them on the same switch
mome rath
Postby isak » Mon Jul 27, 2009 6:15 am
thanks mome rath its working great. :)
but not in the same switch, if i put them together the sound clicks very much when the mod is off.
thanks again :wink:
isak
Postby isak » Sat Aug 01, 2009 2:55 am
Hi guys
can i control on the length of the note in gate mod somehow?
thanks
Isak :)
isak
Postby lazlokovacs » Wed Dec 02, 2009 4:56 am
mome rath wrote:this works very well
How is the "VCA Envelope On Forever"-mod supposed to work? I did the mod, but the envelope is only on forever if I run the sequence and then changes to Keyboard mode, otherwise nothing happens. I want the envelope to be on forever regardless of anything else. I don't have to have the "Gate On Forever"-mod also, right?
lazlokovacs
Postby charlie_says » Wed Dec 02, 2009 10:21 am
@mome
Presumably if you're putting both wires thru the same switch that's a DPST switch??
Or, do you "double up" on the connection to the 12v??
charlie_says
Postby isak » Thu Dec 03, 2009 8:51 am
Hi guys
this is the way and the switch.
isak
Postby charlie_says » Thu Dec 03, 2009 9:03 am
Yeah, that would do it...
Can you post up a sample? (I couldn't find one when I searched thru the forum) I'd be quite interested in hearing how this sounds...
charlie_says
Postby lazlokovacs » Thu Dec 03, 2009 12:37 pm
Yeah, just to be clear if anybody else wonders, the "VCA Envelope On Forever"-mod DOES NOT work properly on it's own, it MUST be combined with the "Gate On Forever"-mod to work. However the "Gate On Forever"-mod does work on it's own.
lazlokovacs
Postby isak » Thu Dec 03, 2009 4:29 pm
lazlokovacs wrote:Yeah, just to be clear if anybody else wonders, the "VCA Envelope On Forever"-mod DOES NOT work properly on it's own, it MUST be combined with the "Gate On Forever"-mod to work. However the "Gate On Forever"-mod does work on it's own.
its not exactly correct the vca env on forever is working gr8 :)
if u play a pattern and hold the slide button in normal mod it will fade out but in the vca env on forever it will keep on going and going ..
and in keyboard mode if its on normal mod if u press the note and keep on pressing it will fade out but in the vca env on forever it wil play forever.
i think that this is the way it should be..if i'm wrog,please correct me.
now, if u take the gate on forever and the vca on forever and combine them this is what u'll get :
View My Video
the first 16 bars is without the mods the second 16 bars is with the gate on forever and vca on for ever.
i hope it helps.
isak
Postby charlie_says » Thu Dec 03, 2009 5:04 pm
thanks isak!
charlie_says
Postby isak » Thu Dec 03, 2009 5:32 pm
you wlecome my friend.
BTW if u'll find the way to control the length of the note on the gate on forever mod please let me know.
thanks
isak
Postby charlie_says » Fri Dec 04, 2009 3:31 am
Funny you should say that. I currently have a VCA decay mod which does very little, but I think I'll add in the Gate on and see how they interect before adding in the VCA on forever.
I'll let you know how I get on.
charlie_says
Next
Return to x0xm0dz
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
