Why does Arduino stop running every 20 seconds?
Postby Daanii » Thu Jan 21, 2010 12:08 am
I'm a beginner running several Arduino sample programs on a laptop with Vista. They all work fine. But with all of them, the program will stop every 20 seconds or so. Then this happens:
-- the "L" light flashes once
-- the program stops
-- the "RX" light flashes once a second five times
-- the program restarts
-- the "RX" light flashes three more times
-- the sequence repeats
It looks like the Arduino is resetting itself when it receives data from the laptop. I'm using COM7. But I cannot figure out why the laptop would send a reset signal. If I shut the laptop, but leave the Arduino connected, it runs fine without any resets.
Any help appreciated.
Daanii
Re: Why does Arduino stop running every 20 seconds?
Postby madworm_de » Thu Jan 21, 2010 12:26 am
Well, you must make sure nothing else talks to the serial port. And it's not the laptop's fault, but some piece of code is misbehaving.
Of course the best way to achieve this would be erasing windows altogether and banish it, burn the banned and send the ashes back to redmond - and ask for a refund for sustained pain!
Maybe you have bloat-ware installed, cell phone syncing software... possibilities are endless for evil things. Try disabling all of that.
madworm_de
Postby charliex » Thu Jan 21, 2010 12:46 am
break it down, does it do it when the bios screen is up? or the f8 choose os screen? this will help determine if its something in windows. try safe mode. try a loopback cable, or null modem to another serial port, or a serial monitor that looks to see if there is anything on the serial.
open hyperterminal or putty to the serial port, if it opens and it still happens its unlikely its a piece of sofware
http://032.la - Null Space Labs.
charliex
Postby Daanii » Thu Jan 21, 2010 12:48 am
You nailed it. I had a cell phone program that was causing the problem. I uninstalled it, and the Arduino works like a charm. Thanks!
[Wish I could do without Windows, but I'm locked in by now. Curse you, Trey!]
Daanii
Postby adafruit » Fri Jan 22, 2010 10:35 am
wow, never would have guessed that! good detective work, madworm!
Postby Kdees » Fri Jan 22, 2010 4:38 pm
I had a similar issue with my netbook, blackberry bluetooth pairing, arduino and the windows blue screen of death. same issue.
attach arduino, open serial monitor... mouse would flake... netbook would blue screen, and the final clue:
blackberry would call my old pal Bill
quick trip device manager and disable blutooth... problem solved...
Made me flash back to the days of jumpers labeled "COM", "DMA" and "IRQ"
K
Kdees
Postby tytower » Sun Jan 24, 2010 12:33 am
For any others with similar problems I have found that an array overflow problem in your programming frequently causes similar resetting problems
tytower
Return to Arduino
Users browsing this forum: adafruit_support_bill and 18 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
