Snap a picture of your ADAFRUIT clock and post it here!
Tick Tock Clock Kits
Re: Snap a picture of your clock and post it here!
Postby Len17 » Tue Mar 02, 2010 11:26 pm
Adafruit Ice Tube
Adafruit Monochron
Retro LED Clock (Warning: May contain traces of adafruit)
Len17
Postby mojo » Wed Mar 03, 2010 8:30 am
Here is mine:
It started as a test for the LED matrix driver, but then I decided to just carry on and finish it. It keeps time perfectly but still needs a few things doing. I need to add some buttons for control (multiple fonts etc), an LDR to dim the display at night and a radio time module (probably GPS because MSF and DCF77 reception here are terrible). I am also working on a nice case for it.
The LED matrix is driven by shift registers with Darlington arrays to sink the required current. Rather than using resistors I instead used LM317 regulators to generate the forward voltage of the LEDs, plus a bit extra because they are multiplexed. I use another shift register and some transistors to switch the LM317s on in turn, one for each row.
There were some issues with the brightness of the display not being quite even. A better power supply mostly sorted them out, but to remove the last imperfections I adjusted the display scanning interrupt to count the number of lit LEDs per row of the display. Rows with more LEDs get a slightly longer time slice to increase their brightness. It seems that the LM317s rise a bit more slowly when there is a larger current draw. I'm not sure if it's the regulators or the PSU, probably a bit of both.
mojo
Postby florinc » Wed Mar 03, 2010 9:14 am
Sorry, I fixed it :)
florinc
Postby adafruit » Wed Mar 03, 2010 10:57 am
folks - adafruit clocks in the adafruit forums, thanks :)
Re: Snap a picture of your ADAFRUIT clock and post it here!
Postby static_neurotoxin » Thu Mar 04, 2010 2:50 am
I just finished building my Monochron! Easy build, everything worked correctly the first time :)
static_neurotoxin
Postby nbcaffeine » Sat Mar 06, 2010 12:30 pm
Put it together last night, but had to wait until this morning to finish, as my kit was missing a 2.2k resistor. It's cool, I know a guy. Not bad for a first time builder, I knew I bought this iron for something! I'm looking forward to my next project.
nbcaffeine
Postby Squar0L » Sat Mar 06, 2010 7:03 pm
Snapped the picture within 3 hours of unboxing!
Squar0L
Postby dataman » Sat Mar 06, 2010 7:32 pm
Well, if the rules are it has to be clock and be from AdaFruit,
There's here's another entry of mine...
DiggClock:
DiggClock, current under development
Bought a Digg kit for my padawan,
Only problem was, Padawan soldered the chip in backwards,
So I cut it off, and swapped it around,
Which accounts for the strange look of the chip.
A little brain surgery and It's talking to a programmer.
The goal here is to leave the digg as stock as possible,
But turn it into a clock.
Since it's not enough digits for a proper clock,
I've recoded the firmware for turn it into a hexadecimal clock.
First digit is hours,
Second two are minutes.
c2e = 12:46
Currently, it's running way too fast,
And doesn't keep time when it goes to sleep,
But it's a start.
Still working on it.
Going to try adding a resonator,
Turn off the sleep mode and power over usb.
Dataman
Charley Jones, crjones.com
Founder and President:
Sql Server Society of Las Vegas, SSSolv.com
XNA User Group, LVXug.Com
Las Vegas Make, LVMake.Com
Developer of the IntruderChron, MultiChron, & GOL 1.4 Mod, Crjones.Com/AdaMods
dataman
Postby chelmi » Sun Mar 07, 2010 11:04 am
Here is mine with Tali, my trusty assistant:
Her role is mainly to sleep under the warm light and steal my brass wool every 5 minutes :p
chelmi
Postby dataman » Sun Mar 07, 2010 4:30 pm
I had to buy an extra chair for Tux (my kitty) when I'm working.
He still prefers whatever chair I'm in, so we trade chairs a lot.
Every time I get up to get a part, he switches chairs.
Dataman
dataman
Postby roughedges » Sun Mar 07, 2010 5:44 pm
Put mine together last night and love it! I may start making these as gifts for people.
No modified firmware yet but I may do that next.
roughedges
Postby mihalis68 » Mon Mar 08, 2010 8:33 pm
Here's my collection of photos taken during my MONOCHRON build.
http://www.facebook.com/album.php?aid=1 ... 7004d6c14c
I"m new here by the way - hi! :)
Chris Morgan
mihalis68
Postby jsabev » Thu Mar 11, 2010 2:25 pm
Here is mine.
Great kit!
jsabev
Postby gatonero » Sun Mar 14, 2010 3:45 pm
After 6 weeks my Ice Tube Clock arrived yesterday. To assemble it was a great pleasure, especially because of the very good explanations on http://www.ladyada.net/make/icetube/index.html :D
I installed Caitsith2 Firmware, which can be found here http://forums.adafruit.com/viewtopic.php?f=41&t=12932&start=0
This is real DIY Open Source Hardware. Thanks a lot!
Ice Tube Clock
gatonero
Postby gatonero » Wed Mar 17, 2010 5:24 pm
Today I presented my Ice Tube Clock at the dorkbot Aachen meeting. I got the chance to make an "obligatory" picture of a clock on top of a clock :wink:
The bottom clock is made by Jan Borchers from The Media Computing Group at RWTH Aachen University. Its name is "The Clock" and it's a study in human design. This clock is amazingly easy to control. Just one turn-switch with push function controls time and alarm setting, also alarm on and off. The alarm time settings circle through 15 minutes steps. When the alarm starts it starts randomly with one of 10 songs / noises (birds, ocean, songs etc.) starting with a very low volume which rises up (conscious no snooze function). Also it has an auto dimming function.
It's driven by a real time chip and two Arduinos. One Arduino controls the digits, user inputs and the second Arduino, which is coupled with an Adafruit Wave Shield and just has the function to play songs and noises.
Isn't it a real nice clock?
gatonero
PreviousNext
Return to Clocks
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
