Helyx525 wrote:MODWHEEL=0, no notes are accented
MODWHEEL=1, only notes w/velocity = 127 are accented
MODWHEEL=20, notes with velocity > 107 are accented.
MODWHEEL=64, notes with velocity > 64 are accented.
MODWHEEL=127, all notes are accented.
sounds cool aswell.. too bad that there will be a while before one can to try such things
one thing that migt be extremly cool aswell would be an extrenal track like we have it on the 909..
an alternativ sequence that is only send via midi...
maybe combined with something like the SEM niessen sequencers midi track... there you can select at each step one of 12 note memorys, instead one of 16 fixed notes on the 909 ( what is extremly usefull allready).. wich contain anything from 1 to 9 notes that are played on this step.. so the extrenal track would be abble to play chord stabbs on top of a 303 line
Once ther is a bigger cpu there are actually many possebilitys.. the infrastructure of the xox with its midi and din sync ports and all sthe buttons.leds and usb is allready quite something..
With the extra pins of a larger cpu its probably not too difficuld to have an extra trigger event sequencer running in parallel... such a simple thing would allready be a usefull adition..
like in the old ppg sequencer.. there was the main sequenz but 2 extra trigger tracks to start additional enevlopes or step other sequencers..what allways is extremly nice to build nested sequences..
I ve an trigger out on accents for that reason on my xox..but an independent trigger track would be even better...
However..such gimmicks are probably much easier to program than a propper 303 style sequencer and all the clocking, dumping, editing routines...
so first things first i guess
